D2300 - good deal?
   / D2300 - good deal? #1
mkeeney
Rome, GA
Mitsubishi D2300
I have found a D2300 2wd with loader locally. The guy is asking $5800. From my research, it appears to be a rare model. Does this sound like a good deal? Will I be disappointed with the 2-cyl. engine? It's rated at 27 hp. Will it pull a 5 ft. bush hog, or should I stick to 4 ft.? Also, are there any common problems I should check for? Thanks for any advice!
   / D2300 - good deal? #2
While the tractor model number may not be found too often, it is far from rare. The following models are virtually identical: Satoh S-630, ST2001, ST2300 and Mitsubishi D2000 II. Also similar but not identical are the ST2000 and D2000. The 2 cylinder engine was rated in the U S literature as 25 hp. It does not run as smoothly as a 3 or 4 cylinder model but it is a tough old motor. This tractor was built between 1976 and 1981. Parts are currently available and I don't forsee a problem anytime soon. We can provide parts and manuals. My own feeling is you'd be better off with a 4 ft bush hog but it will pull the 5. Bill - satohparts.com
1986 Nissan King Cab Pickup (A52384)
1986 Nissan King...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
