D170 K46BE rebuild prime question
   / D170 K46BE rebuild prime question #1
Tte531
JD D170
Rebuilt and installed:
Got the trans installed and noticed I cannot get it to roll freely when manually pushing. I figured let’s just see what happens when there is pressure from a running motor.
Fired her up and had to adjust the bypass lever a bit but I was able to get it going in forward and reverse. However, she sounded aweful, like every thing that could grind was. Also when I let off forward it locked up the wheels to stop.
Repulled trans again to inspect:
When I pulled the trans and dumped out the fluid it was metallic and I thought FML… however I cannot see any noticeable wear and the aluminum pump housing has no noticeable wear. The pump case looks good and I can spin the ‘motor’ freely.
I checked the bypass pin again before putting the case cover on and all is well.
When I go to prime the axle on the bench I cannot put the trans into forward or reverse without it locking right up. If I hold forward/reverse and spin the pump by hand I seem to hit a noticable wall where I cannot spin the pump anymore. If I let off forward/reverse I can’t spin the pump freely.
Why would this be?
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2017 Ford F-250 Reading Service Truck (A55852)
2017 Ford F-250...
(1) 5' X 4' TRAILER TAILGATE (A57192)
(1) 5' X 4'...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
UNUSED FUTURE XJ5T 36" HYD THUMB CLAMP (A57193)
UNUSED FUTURE XJ5T...
