d1650 fuel filter problem
   / d1650 fuel filter problem #1
texas
satoh st1620 4cyl diesel
i have a D1650 and the fuel filter plastic bowl has cracked and i can't seem to find a replacement. could i replace the fuel filter assembly with something else, maybe a metal inline filter with a shut off valve? thanks:thumbsup:
   / d1650 fuel filter problem #2
I wouldn't see why not. Make sure the replacement is intended for diesel fuel and has a way to bleed air if necessary.
kj
   / d1650 fuel filter problem #3
You might want to check with your local Cub Cadet dealer for a cross-referenced part. Mine used a Cub 7193 filter bowl. Cost was less than $5.
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2016 UTILITY VS2RAP 53FT REEFER TRAILER (A54607)
2016 UTILITY...
