D1650 front axle oil capacy
/ D1650 front axle oil capacy #1
pacer1980
Greenwood La USA
Kubota BX25D Mitsubishi D1650
Recently got a pretty decent D1650 with a couple pretty minor probs - one was the seals on the stub axles up front were leaking badly. Have got the seals coming and should be re-assembling in the next few days. My question is: what is the capacity of oil in the axle? Even with it been leaking for some time the amount of oil that drained out was quite a bit. I see the fill points on the axle housing but nothing to indicate when enough is in. I was expecting to find a pipe type plug on the side somewhere to remove and fill till oil ran out --- but dont see such a thing. So does some one know what the capacity here? would think its gonna need a gallon or more....
/ D1650 front axle oil capacy #2
There should be a fill/level plug on the center and one on each side near the wheel.
/ D1650 front axle oil capacy #3
Hello
I have a Mitsubishi D1650 FD
I need a datasheet or technical data for this tractor. Do you have something or can get something or can give me a tip where I get such data from?
Thank you for your efforts
Best regards
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
UNUSED IRANCH IRTPL 10000Ib TWO-POST CARLIFT (A60432)
UNUSED IRANCH...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
2021 BOBCAT S66 R-SERIES SKID STEER (A60429)
2021 BOBCAT S66...
Toro (A56857)
Toro (A56857)
CATERPILLAR 926M 99" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 926M...
