D1650 front axle oil capacy
   / D1650 front axle oil capacy #1
pacer1980
Greenwood La USA
Kubota BX25D Mitsubishi D1650
Recently got a pretty decent D1650 with a couple pretty minor probs - one was the seals on the stub axles up front were leaking badly. Have got the seals coming and should be re-assembling in the next few days. My question is: what is the capacity of oil in the axle? Even with it been leaking for some time the amount of oil that drained out was quite a bit. I see the fill points on the axle housing but nothing to indicate when enough is in. I was expecting to find a pipe type plug on the side somewhere to remove and fill till oil ran out --- but dont see such a thing. So does some one know what the capacity here? would think its gonna need a gallon or more....
   / D1650 front axle oil capacy #2
There should be a fill/level plug on the center and one on each side near the wheel.
   / D1650 front axle oil capacy #3
Hello
I have a Mitsubishi D1650 FD
I need a datasheet or technical data for this tractor. Do you have something or can get something or can give me a tip where I get such data from?
Thank you for your efforts
Best regards
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
