D1600 II Oil help
   / D1600 II Oil help #1
Jeremy_R
What type oil do I use in the gearbox and how full should it be. I also discovered an oil leak where the brake linkage is going in to the axle on the right side. Is this just a seal or will I have to pull the whole thing apart.
Jeremy
   / D1600 II Oil help #2
It is either 90w or utf (universial tractor fluid) if it is thin line 20w oil it is utf. It is is very thick oil it is 90w.
leak is most likely a seal.
   / D1600 II Oil help #3
Use 80w90 gear oil unless you have a loader. In that case use a quality tractor hydraulic oil. Level plug is on the right side of the transmission. Look for a bolt head in the middle of the case just behind the diff. lock pedal about half way up the side. You probably have a bad seal in the brake housing. Is not difficult to replace. For parts or manuals call toll free 1-800-609-5110. satohparts.com
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
2017 Chevrolet Express 2500 LT Passenger Van (A51692)
2017 Chevrolet...
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
