D series Toolcat Laser Grader?
   / D series Toolcat Laser Grader? #1
panther1400
Someone told me that a toolcat cannot run a box blade or grader with a laser, but my 12 year old 753 might be able too, what do you guys think?
   / D series Toolcat Laser Grader? #2
Both are listed as approved on the Bobcat website and are in the brochures. I would like to try the box blade for use on gravel driveways.
dsb
Box blade is much cheaper than a grader, but how do you crown a road with a box blade?
   / D series Toolcat Laser Grader? #4
I wouldn't get a crown with the box blade. I currently use a 3pt blade which doesn't really crown either. It's not a big problem with my driveways and works better for clearing snow with the bucket and blower.
I can't justify the cost of the grader for the 30 minutes it takes me to dress the driveways a few times a year and have used box blades on tractors in the past with good success.
dsb
   / D series Toolcat Laser Grader? #5
Panther, there IS a box blade that Bobcat has out that works on the Toolcat. It is P/N 6906574. There is also a box scraper, P/N 6958483 that will work on your machine as well. As far as the laser use, I don't see the point for a driveway. It's over 10K for a transmitter, receiver and harnesses. Plus, the Toolcat is not wired like the skidloaders and it will not run the blade with a laser attached as the Toolcat has no BICS on it.
The box scraper works GREAT on the Toolcat. It has a cutter edge on the rear that swings away when going forward but cuts when backing up. Mount it on a Tilt-Tach and you can crown your drive very nicely.
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
John Deere RSX860i (A56469)
John Deere RSX860i...
CATERPILLAR D6 CRAWLER DOZER (A52707)
CATERPILLAR D6...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
