Cylinder weight scale
   / Cylinder weight scale #11
It wouldn't matter what position the curl cylinders were in if you tap the primary feed to the lift cylinders before the split and after the control.
The curl position changes how far from the lift arm the center of the load is. Rolled all the way back is a slightly shorter lever.
   / Cylinder weight scale #12
Yes. AND the load itself is not going to have a center-of-gravity perfectly centered over the COG of the
bucket or pivot point. That is why crane scales are suspended from a point.
   / Cylinder weight scale #13
If you look on Ebay, you will often see used dynamometers in the $50 - 100 range.
Ken
   / Cylinder weight scale #14
on a loader the weight will be approximate, as the length of the center of the weight can change, as stated, but if you are just seeing if the bucket of dirt is not going to over load your truck or how much the fire wood weight's or how much hay for the cattle, most likely it is good enough, but but if you want to know very close your going to have to use a single pint unit like a hanging scale type, so the weight center is the same regardless,
2001 PETERBILT 378(INOPERABLE) (A45046)
2001 PETERBILT...
Kawasaki Mule 2510 (A44391)
Kawasaki Mule 2510...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
Honda Gold Wing GL1200 Aspencade Motorcycle (A44572)
Honda Gold Wing...
2004 Ford F-150 Pickup Truck, VIN # 1FTPW12524KD06090 (A44391)
2004 Ford F-150...
INOP/NON-RUNNING 2007 Kenworth T800 Truck, VIN # 1NKDX0EX87J172444 (A44391)
INOP/NON-RUNNING...
