Cylinder weak and slow
   / Cylinder weak and slow
Ok I'd suspect the valve. I'd drop the bottom cup, it's usually held on with 4 cap screws, you can probably get at it without dismounting the valve. If that's a detente valve all kinds of little bearings and springs may fall out, be ready. If it's full of crap that's probably the problem, but even if it isn't try using the valve with that cup off. If it still doesn't work you may need to take it to hydraulic shop depending on your ambition.
The other thing, since it's so old, if you remove the valve lever and take the top boot off, inspect the condition of the spool where it enters the valve body. If it's built up rust over the years that might be preventing the spool from moving all the way into the body.
I removed the cup and everything looked new inside. Lever side looks good too. The cab covers the controls so I’m sure that helps. Looks like the spool assembly will have to be taken apart. Not sure I’m up for that task though I will most likely take it to a shop.
   / Cylinder weak and slow #12
OK, didn't realize valves were in a cab, I thought they'd been outdoors since 1975. Just to be sure what you did to diagnose this, did you switch a different valve to this same cylinder, or did you just reverse the hoses? If you didn't do it, just as a double dog check I would connect this valve to a different cylinder and verify the cylinder has a problem. Also connect a different valve and make sure this cylinder works OK. If you already did that, then yes it probably needs some work internally, or at least I'm out of ideas. It's not hard to pull the spool out, just be gentle and make sure you keep everything really clean. Ask your wife for a clean sheet, they love it when you get hydraulic fluid on them. Once you pull the spool look for any burs or flat spots on the spool that might be causing it to not move all the way in one direction. You can clean the small passages in the valve body and the spool with solvent and compressed air. You can't hurt anything as long as you handle it carefully, it has very tight tolerances so you have to rotate and wiggle it around as you remove or insert it. The orings are probably hard, you can replace them but they only seal low pressure. Or you can just take it to a shop, they can test it on the bench and confirm there's a problem internally before they take it apart.
   / Cylinder weak and slow #13
I did notice on that handle when I pull it all the way toward me it will stick,,, none of the other handles will do that.
I just noticed this sticking you mentioned. That could be a bur on the spool that's preventing it from moving all the way.
3in Poly Pipe (A49461)
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
LINDE H80D FORKLIFT (A50854)
LINDE H80D...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
VERMEER RTX450 (A50854)
VERMEER RTX450...
