Cylinder seal replacement ?
   / Cylinder seal replacement ? #1
deans
Ontario, Canada
A/C c, Yanmar 155D, Kubota
I have an ARK loader with 2 '' cylinders that have internal snap rings on either end. I removed snap rings and cannot remove end caps. They are not threaded and no corrosion, but they will not budge. Soaked with penetrating oil overnight, no luck, anyone have a thought on removing the seal end cap . Regards, Dean
   / Cylinder seal replacement ? #2
A picture is worth a thousand words! I'm not familiar with that loader or it's components. On one cylinder I have there is an external snap ring and then I have to push the end in to get at the internal snap ring. Worth a look maybe?
EDIT: I just reread and see that you have internal snap rings and have them out alread, maybe pull the rod out?
dave
   / Cylinder seal replacement ? #3
Yes, good pics help since they are many methods used for gland retention.
I have tried to push gland inwards to see if a lock wire was inside, gland will not move, put a 5/8 steel pin in rod end and mounted in large vice, and tried slide hammer style in pulling rod/piston/gland out of tube. it will not move and I am not feeble. I have repaired numerous cylinders at work over the years, but a small 2''diameter x 18'' stroke has me stumped.
   / Cylinder seal replacement ? #5
oxy/acet heat is your friend, but don't overdo it......when it seems it is too hot (never red), set it aside and wait till cool to resume
Sometimes the hot and cold cycle will help, multiple times if needed
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A54757)
UNUSED RAYTREE...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2016 John Deere 755K Crawler Loader (A47477)
2016 John Deere...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
