Cylinder Rod End Style Question
   / Cylinder Rod End Style Question #1
Bean Juice
John Deere 650
I have tube style rod ends on my old Kubota. 4 of the 7 hydraulic cylinders on the machine have bent and pitted pistons to the point the repair place I took them to to said they wouldn't rebuild them. Kubota wants $1400 each for replacements, and I can't find aftermarket cylinders with the dimensions of these with a tube/pin style ends that are large enough to fit the pins on my tractor. I did however find cylinders that will fit with clevis style rod ends. FWIW I can easily make spacers and or bushings to mount these new cylinders. So I'd like to know, is there a reason I shouldn't use a clevis style hydraulic cylinder to replace these worn out cylinders on my backhoe and loader?
   / Cylinder Rod End Style Question #2
The tube style ends hold the grease for the pins..
   / Cylinder Rod End Style Question #3
With your stated abilities, no reason why you can't. Just consider how you are going to grease them.
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2019 ExMark Lazer Z S-Series 72in Zero Turn Mower (A51691)
2019 ExMark Lazer...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
RoGator RG1100C (A53472)
RoGator RG1100C...
