Cylinder Rod End Style Question
   / Cylinder Rod End Style Question #1
Bean Juice
John Deere 650
I have tube style rod ends on my old Kubota. 4 of the 7 hydraulic cylinders on the machine have bent and pitted pistons to the point the repair place I took them to to said they wouldn't rebuild them. Kubota wants $1400 each for replacements, and I can't find aftermarket cylinders with the dimensions of these with a tube/pin style ends that are large enough to fit the pins on my tractor. I did however find cylinders that will fit with clevis style rod ends. FWIW I can easily make spacers and or bushings to mount these new cylinders. So I'd like to know, is there a reason I shouldn't use a clevis style hydraulic cylinder to replace these worn out cylinders on my backhoe and loader?
   / Cylinder Rod End Style Question #2
The tube style ends hold the grease for the pins..
   / Cylinder Rod End Style Question #3
With your stated abilities, no reason why you can't. Just consider how you are going to grease them.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
