Cylinder repair Ford backhoe
   / Cylinder repair Ford backhoe #11
Glad you got it running again Loopman but someone saw you coming....that seal kit should've cost much less than that
What was the dimensions of the cyl (rod dia, bore dia)
The 4500 kits I make up piece meal but they should not run much more than $100-150
   / Cylinder repair Ford backhoe #12
Job done! :)
What would be the indication of piston seals leaking? - low 'strength' from the cylinder, slow movement etc ???
Less power, slower under heavy load, and bleeding down faster than normal are all symptoms that could indicate piston seals.
BUT, all of those symptoms could also come from a worn out valve spool as well.
Maybe they did ?
Stabilisers are 3 1/2 " cylinder with a 1 1/2" rod (from memory), Ford/New Holland seal kit from an old manual has part number '309938' - local hydraulic agent said these were going to be $460 EACH cylinder (genuine parts sourced from Ford/NH in the US and freighted to Australia).
As I said, just ended up getting the gland seals, for these rams alone this was $13 PER seal, 5 x per cylinder = $65. (Larger ones for the crowd cylinder were $24 each = $120 just for the gland)
   / Cylinder repair Ford backhoe #14
Maybe they did ?
The rod seals (v-packing sets) are standard sizes but the piston v-packings are unusual ford only......some bores are 3.520 ect......next time you get one apart measure the bore and id of the seals (assuming they are v-packings) and the height.......I have them in stock and can at least give you a part number to order online somewhere close to you
Thanks, will do, although fingers-crossed I won't have them apart for some time now :)
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
2015 Peterbilt 337 Pac-Mac KBF-20H Forestry Grapple Truck (A55788)
2015 Peterbilt 337...
R-134A Manifold Gauge and Hose Set (A55218)
R-134A Manifold...
2008 UTILITY VS2DX DRY VAN TRAILER (A54607)
2008 UTILITY VS2DX...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A55787)
2017 JLG Skytrak...
