Cylinder rating
/ Cylinder rating #1
jhlittle
As I've stated before I don't know much about hydraulics. Is there any way to tell what a cylinder is rated for based on measurements? I have 2 cylinders that were given to me but we don't know what their capacity is.
Thanks
/ Cylinder rating #2
A hyd shop probably can run some test to see what the pressure limits are.
They test things like pressure, bypassing, etc.
/ Cylinder rating #4
You can get some idea, yes. The biggest factor is whether they are tie-rod or welded construction. Tie
rod cyls depend on the tie rods to keep the ends on, so they are low-pressure. 2500psi is the highest I have
owned. Many are 2000psi or less.
If they are welded construction, the cylinder wall thickness can give you some indicator. I have measured
a low in the range of 0.17", all the way up to 0.30". The welded cyls I have bought have not been rated
lower than 3000 psi.
Then there is the internal seals, but that's getting into the weeds. Simple O-ring and scraper seals on
the piston, for example, will be found on lower pressure cyls, versus U-cup or other seals.
Finally, note that a lab test on a cyl will need to apply pressure that may be over 1.5x-2x the rated
pressure before you will see a failure.
Since this is a tractor site, note that most tractors owned by TBN members put out less than
3000psi. You usually have to go industrial or skid-steer to go higher.
/ Cylinder rating #5
NFPA Tie rod cylinders are rated to 3000 PSI but are very rare in ag or construction equipment.
/ Cylinder rating #6
Prince Fortress Welded Cylinders
Has welded cyl rated at only 2500 and they also have TR/tie rod cyl rated at 3000 psi,
It would be hard to judge/determine by looking at a cyl.
Even testing a cyl might damage it.
Baileynet test their cyl at 1.5 times the psi rating.
I would guess the avg psi on tractors is about 2500 psi, maybe lower.
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
Isuzu Diesel Engine 6 Cylinder (A64912)
Isuzu Diesel...
PALLET OF FLANGE CUT-OFF VALVES (A67714)
PALLET OF FLANGE...
60' Spray Booms (A64912)
60' Spray Booms...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
Tracker OX400 (A64912)
