Cylinder question?
/ Cylinder question? #1
GreatWhitehunter
Eastern CT
JD 110 TLB
I have a JD snow plow that I want to put hydralics on. It already has the posts for the cylinders to be mounted on both sides. My question is how do I figure the size and stroke of the cylinders. It has mounts on both sides of the plow pivots so I'm thinking I need two. Or can I just get away with one larger cylinder?
Matt T.:D
/ Cylinder question? #2
What model plow is it? maybe with JDParts I can help you figure it out.
Do you have a picture?
/ Cylinder question? #3
I have a LandPride rear blade. It has mounting on both sides of blade arm. My 3" X 8" cylinder is put on one side. If I need extra angle on other side I move the cylinder to that side.
/ Cylinder question? #4
I'm taking a stab at this. I'd guess it is one of their 54" models??
Like this one?
They've been in production for many years, and from what I can tell they use the same cylinder. 10" closed, 14" open. It's a small stubby cylinder.
When your Plow is in the straight position, measure from center-of-hole to center-of-hole of the Power Angle brackets (the ones on the left as you look at it from the driver's seat.
Is it about 12"?? (Mid position for the power angle).
Then it is the "standard" cylinder found on those plows.
Tell us some Specs of the plow you are referring to and we can help more.
/ Cylinder question? #5
Regardless of what plow you have, all you need to do is measure for what you need. Angle it one way and measure the short side for the retracted (closed) distance and the long side for the extended distance. Then find the closest cylinders within your budget with the right ends for attaching to your plow. I would be looking at 2"-3" diameter cylinders...
/ Cylinder question? #6
Matt T.:D
Guess i misread your post. Get the model # JD plow you have and look up the parts. I needed parts to mount a JD snow blower on my F735 front mower. JD's price was way out there. Looked on EBAY bought all the mounting hardware for less than $50 with shipping.
The JD model number is not there. I'll try to post a few pics later today. I'm going to angle it and see the retracted distance.
Matt T.:D
I finally got around to measuring the plow angles. It seems I need a cylinder that is 13-1/2" closed and 21-1/2 open. I looked at Northern tools for a close match in size. Is the closed pin center the total length of the cylinder closed? If so where do I find a cylinder to work in my situation? I'm new to the hydralics game. Is there online source for these? I really need to get something ordered fast as winter is upon us here in the Northeast.
Thanks
Matt T.:D
/ Cylinder question? #9
/ Cylinder question? #10
OK, so you need a 8" stroke cylinder. Now we need to know what size the pins are that's on the plow? How about those pictures you promised?
Kenny, I'm sorry I failed on the pics. I've been so busy with everything else. The pins are 3/4" I'm home sick today so I'll try and get them later today.
Thanks
Matt T.:D
/ Cylinder question? #14
This one has a smaller bore would it still be ok? Surplus Center Item Detail
Thanks
Matt T.:D
This cylinder is kind of on the light side, but it should work okay. The only thing that I would be concerned about is hitting something with the cylinder extended, the rod is only 3/4" and won't take much to bend it. I wouldn't go ramming any snow banks.
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
2014 F-150 4WD (A63689)
2014 F-150 4WD...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
