Cylinder or valve problem ?
/ Cylinder or valve problem ? #1
Reg
Elite Member
As a GENERAL question; how do you go about figuring if "leak down" is in the cylinder or the valve block ?
e.g. If you leave the loader up and it creeps down overnight.
It might not be a huge problem, other than you shouldn't do it for safety reasons, they probably all do it a bit, but on the hydraulics troubleshooting question how do you figure if it is leaking past the piston or past the valve ?
Same with the hoe boom. Sure, I should either put it down or pin it up, but how can I figure out if it is valve or cylinder piston leak down ?
Assuming there are no puddles, etc.
/ Cylinder or valve problem ? #2
They way I do it is to raise the FEL or boom and rest it on a jack, then remove the hose or QD nipple on the side of the cylinder that is NOT pressurized, then carefully lower the jack...if you get fluid out of the hose then the fluid is bypassing the seals in the cylinder.
/ Cylinder or valve problem ? #3
What kenny said, except run the ram all the way out then remove the other side's hoses. Then extend the ram more (pressure relief will operate, don't worry). If you are leaking past the seals, it will come out the open port. Do both at once and see if both are bad or just one.
it's 99% cylinders. Probably be safe just rebuilding them yourself. easy to do.
/ Cylinder or valve problem ? #4
If possible swap the hoses to a diiferent valve, if that solves the problem you know it's the valve.
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
John Deere Tractor Fenders (A65640)
John Deere Tractor...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
