Cylinder location 184 Low Boy
   / Cylinder location 184 Low Boy #1
mickeyt
Hegins Pa.
IH 185 Low Boy
any body know where cylinder (piston) # 1 is located ? Radiator or seat end?
Also how many turns of the engine does it take to bring #4 piston to tdc on compression after you adjust the valves for when piston #1 is at tdc on compression?
   / Cylinder location 184 Low Boy #2
Its really hard to answer this question not being able to see the engine, but im pretty sure that cylinder one is on the radiator side. The firing order is 1-3-4-2.
Thanks, now I have to figure out whether the valves are adjusted correctly. Two of us worked on it after valves 7 & 8 were replaced and are not sure if they were adjusted in the right order (proper procedure) as far as how many turns of the engine to get 1 and 4 up at tdc (on compression) since cylanders 1 & 4 come up at the same time and adjust valves 1235 and then 4678.
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2018 Chevrolet Equinox AWD SUV (A53424)
2018 Chevrolet...
Bale Spear - Fits John Deere 300/400/500 Series Carrier (A55218)
Bale Spear - Fits...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A51406)
2012 INTERNATIONAL...
30007 (A53424)
30007 (A53424)
