Cylinder Leak Down test?
   / Cylinder Leak Down test? #21
Same thing.
I see all the theory, and I fully understand it...but there are a LOT of people who've had major leak down issues and found bad piston seals and corrected the issue with replacing them. Tha's the part I'm hung up on...theory vs. real world.
   / Cylinder Leak Down test? #22
That has a simple explanation, both the valve and cylinder seals were faulty.
If the valve passage that holds pressure to the rod side of the cylinder is leaking by, AND the cylinder pistons are faulty.....oil bypasses the cylinder piston seals and exits the cylinder via the rod port and back through the valve.
Replacing piston seals will give the appearance that it has solved the issue. And in reality.....it has. Because you cut off any pressurized fluid that would have been able to escape. But replacing the valve would have also solved the problem. Because the piston seals ALONE cannot cause a drift. Even if removed.
I am sure there have been far more cylinders rebuilt with the expectation of fixing a loader that leaks down, that resulted in less than desirable effects.
The whole issue is.....its quite simple to test the cylinders. And too many people regurgitate the bad advise of "cylinders probably need rebuilt" when someone askes about loader drift. Rather than proper education on how to actually test and isolate the problem.
Look at snow plow single acting cylinders. There is no piston or seal at all.
   / Cylinder Leak Down test? #24
If you had 2 double acting cylinders in parallel (loader configuration) both with bad internal seals, it would essentially act like 2 single acting cylinders. Push down on one cylinder & the other would raise. There would only be the loader frames ability to prevent twisting.
1 double acting cylinder with a bad seal in parallel with one with a good seal should still work somewhat properly. It would get wierd as various chambers could get put under a vacuum. Mostly when pulling on one of the clinders.
As Jim says, what you are missing is that when the cylinder is retracting, in order for the rod to have room to enter the cylinder that same amount of oil has to go somewhere else. That much oil has to completely leave the cylinder.
Im thinking the oil is seeping past the seals so the oil is displaced to the other end of the cylinder. Much like if an engine has bad ring seals the combustion mix can enter the lower end. Sorry Im still at a loss. And more confusing where some people are talking the valve. The valve is completely disconnected so the issue must be with the cylinder rod seals.
   / Cylinder Leak Down test? #26
I thought about just removing the packing - or the O rings - depending on which one a particular piston uses. But decided to drill the holes in the piston instead. Partly for the visual, and also because the packing helps keep the piston tight in the cylinder bore. When the piston is tight it can't slop sideways which helps to keep the rod end seal from leaking oil out or air in.
rScotty
Or just remove the piston. :)
   / Cylinder Leak Down test? #27
Let's talk about the loss of lifting force if the piston seals are bad. In theory, we would only have lifting force equal to the rod area times the PSI. But in reality it is a dynamic where flow rate at a given PSI and leakage pass the piston seals come into play. Right?
   / Cylinder Leak Down test? #28
As a lower bound, if you took the piston off the end of the rod, the hydraulic lifting force would be the pressure times the cross sectional area of the rod end, assuming the pump had enough capacity to maintain pressure with that big a "leak". So if the piston diameter is 2 sq-in and the rod end is 1 sq-in, the lifting force without the piston would be 1/2 the lifting force with it. Obviously a leak has much less impact than removing the piston, so the loss of lifting force is much less. Again the pump has to maintain pressure against the leak, but seat of the pants I'd guess you could get to a 10-20% loss of lift before the leak was so big the pump couldn't maintain pressure.
   / Cylinder Leak Down test? #29
In theory no internal seals on a double acting cylinder would give you rod surface area * PSI force. With seals it would be cylinder area * PSI. There is no rod to cylinder constant, but it's probably only 1/3 strength in many cases.
If the internal seals are there but leaky, you'd get something between those 2 numbers, depending on how fast it could leak.
   / Cylinder Leak Down test? #30
Getting off topic....but in reality....with no pistons in a DA cylinder....actuating the valve would probably just make the loader drop.
If they were SA cylinders....or had the rod port plugged....then yes....force would be PSI x rod area. But without the port plugged ....and no piston....the oil simply comes in the base port and free flow out rod port to tank
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
UNUSED RAYTREE RMLS18T HYD LOG SPLITTER (A54757)
UNUSED RAYTREE...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
