Cylinder fitting leak
/ Cylinder fitting leak #1
Millalien
Bronze Member
Skamania County
John Deere 3320 (2008)
I ran the 'hoe for hours and hours and one of the fittings on the dip cylinder started weeping/leaking - it'd rotated itself counterclockwise about a 1/4 - 1/8 turn. When it was hot I could rotate it snug by hand, which can't be right - and it's still leaked anyway. I didn't want to overtorque it, so it's hand tight now but still leaking. I'm going to pull the fitting out and re-set it. Is there thread seal of some kind that might have broke down? Should I use thread seal when I re-set? Torque ?
Thanks all ---
448 BH on Deere 3320.
/ Cylinder fitting leak #5
need to know what kind of fitting it is.. pipe, orb ?? orf?
soundguy
Thanks all ---
/ Cylinder fitting leak #7
I don't think snug is good enough. Tighten by hand, no way.
1024 (A63111)
1024 (A63111)
2015 PETERBILT 389 T/A 6X4 SLEEPER TRUCK TRACTOR (A69167)
2015 PETERBILT 389...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
213078 (A64276)
213078 (A64276)
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
