cylinder end cap removal?
/ cylinder end cap removal? #1
jeff408
Randle WA
JD 4300
I have a 98 JD 4300 w/ 430 FEL. I am trying to rebuild the front main lift cylinder. I made a tool to fit the hole in the end cap but cant seem to break it loose. Anyone have any suggestions that might help.
Thanks, Jeff
/ cylinder end cap removal? #2
Thanks, Jeff
I'm assuming the cylinder body is clamped in a vise (hopefully with aluminum jaws). And, you made a spanner wrench to fit the holes/slots in the end cap.
How long is the handle for the tool you made? You may need to use a helper bar on the handle of the tool (add some mechanical advantage). That cap has been on the cylinder for 12 years, so there might be a bit of corrosion.
/ cylinder end cap removal? #3
JD has used two different types of cylinders over the years...Please post a picture or the S/N of the loader so I can help you correctly.
/ cylinder end cap removal? #5
Mine have the two slots for a tool I guess. I used a chisel in the slot and a hammer on the end of the chisel. Once it moved I could do it with my hand.
For keeping it from turning I put a long rod through the opposite end and no I dont have an extension on it yet. I just wanted to make sure thats all it needed was a little more convincing before really started torquing on it and then find out there was something else that was suppose to be done also. I have seen the 2 different types posted on here. It is not the one with the snap ring on the end, it has the screw in collar. Mine kind of has 2 holes too but one looks like its just for the hyd fitting.
/ cylinder end cap removal? #7
Here is a parts diagram:
Thanks everyone for the help.
Cat CB24B (A60462)
Cat CB24B (A60462)
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
Caterpillar 988G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 988G...
2020 International LT625 48" Sleeper (A62613)
2020 International...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
