cylinder blowing vent cap off
   / cylinder blowing vent cap off #1
alby
ford jubilee
I installed new cylinders for front bucket lift on my ford jubilee tractor about 3 years ago.The cylinders are double acting, but being used as single acting(1hose&a vent cap on upper end).They've been working fine until now,the vent cap blew off one cylinder so i put a new one on, used it a while(lifted fine)and it blew another one.With the vent cap off, it pushes fluid out on the up stroke but it does lift.The other cylinder has never bothered, the fluid level is o.k..I don't know if it's a problem with the cylinder or something else in the hydraulic system. Any help would be appreciated-Thank you
   / cylinder blowing vent cap off #2
Welcome to TBN:D
If you are getting fluid out of the port that is vented-then that indicates the piston seals are leaking/bypassing, the cylinder needs to be rebuilt.
   / cylinder blowing vent cap off #3
2nd Kennyd, probably have enough oil in the vent that air doesn't flow freely and pressure builds up, then pop!:mad:
   / cylinder blowing vent cap off #4
After the cyl is rebuilt, it's always a good idea to add fittings/hose to the vented ports and route them back to tank.....it will keep dirt/condensation out of the cyls....
Sometimes the vented cyls get rusty inside the bores internally.....it may extend the seal life next time......
   / cylinder blowing vent cap off #5
I have converted these to piston displacement cylinders with great success. I never liked vented single acting cylinders.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2014 Ford F-350 Western Mule 2,000 LB 1 Ton Crane Service Truck (A51692)
2014 Ford F-350...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2014 Dodge 5500 4X4 Bucket Truck (A53473)
2014 Dodge 5500...
JOHN DEERE 6615 TRACTOR (A51406)
JOHN DEERE 6615...
