Jan 5, 2015 / Cylinder and measurements for bx2763a blade Thread Starter #11 OP J Jj1479 Silver Member Joined Jan 3, 2015 Messages 129 Location Hooversville PA Tractor Kubota bx25 ericher69 said: Looks good! Are you bolting on a reversible cutting edge? Sent from my iPhone 5s 64Gb using TractorByNet Click to expand... Yes. I already got 2 pieces of Hardox 450 plate to use. Those will out last the tractor.
Jan 6, 2015 / Cylinder and measurements for bx2763a blade Thread Starter #12 OP J Jj1479 Silver Member Joined Jan 3, 2015 Messages 129 Location Hooversville PA Tractor Kubota bx25 Well its finished. Just another coat of paint tomorrow.
Jan 8, 2015 / Cylinder and measurements for bx2763a blade Thread Starter #13 OP J Jj1479 Silver Member Joined Jan 3, 2015 Messages 129 Location Hooversville PA Tractor Kubota bx25 Well all done. A bit tacky yet due to the oil based paint an the fact that its only -3 outside but going to mount it today.
Jan 8, 2015 / Cylinder and measurements for bx2763a blade #14 G geneP Platinum Member Joined Jun 28, 2000 Messages 842 Location Central Mississippi, USA Tractor Case-International 385, Kubota L5450 w/LA1150A loader Congratulations. That is very professional-looking work. I can imagine what it would look like if I tried to build it.
Jan 8, 2015 / Cylinder and measurements for bx2763a blade #15 CHDinCT Veteran Member Joined Jul 12, 2008 Messages 2,440 Location Conn. & Florida Tractor Kubota BX25, Z422-KW Nice fab job. Probably more heavy duty than the version Kubota sells. Maybe I'm not seeing it, but how are you going to mount the angle cylinder?
Jan 8, 2015 / Cylinder and measurements for bx2763a blade Thread Starter #16 OP J Jj1479 Silver Member Joined Jan 3, 2015 Messages 129 Location Hooversville PA Tractor Kubota bx25 CHDinCT said: Nice fab job. Probably more heavy duty than the version Kubota sells. Maybe I'm not seeing it, but how are you going to mount the angle cylinder? Click to expand... It's going to mount on the left side but they didn't have the cylinder I wanted in stock when I called so decided ill just weld the mounts on when it comes in. I want to try it out an don't want to wait...
