cx2510 front axle oil change
   / cx2510 front axle oil change #1
Taryn
New Hampshire
Kioti CX2510
Hi all!
I am doing my 50 hour maintenance this weekend. I changed the front axle fluid yesterday after work, thinking that would be quick and easy. It would have been quicker if I hadn't stopped to cuss out the engineers.
I realized it would get a little messy when I noticed the placement of the drain plugs, but aside from tucking a spade shovel under the tire to catch the excess (dirt driveway, I didn't poke at the tire), and various methods to get the fluid from A to B, none of my ideas really worked well. I'm just curious, as an afterthought, how others have handled this.
While I'm here, I am questioning the hydraulic filter change. I have the backhoe attachment, and I don't want to take it off just for that, but the height seems limited for a quick swap. I'm sure this is going to sound stupid, but what do you think is the best method for lifting the machine a bit (safely)? Would jack stands or ramps be okay? I also have a hill to flat spot that might work with chocking, but that makes me nervous.
I watched Baznasty Dave's video and I'd like to try that shop vac trick to hold the fluid back a bit.
Now I'm off to buy a filter wrench. I haven't done my own tune ups since they did away with distributor caps (yes, I'm that old!), and yesterday I remembered how much I hate wrenching anyway.
TIA for any and all advice!
   / cx2510 front axle oil change #2
Why not have the dealer service your tractor right at your place? Talk with and watch the technician to learn how to do some of the regular maintenance. Tackle the job yourself the next time….😉
   / cx2510 front axle oil change #3
Skip the filter wrench and get a large set of channel locks for the filters.
   / cx2510 front axle oil change #4
Greetings, new member here. I am curious to know if you refilled the front axle with hydraulic fluid that originally came with the tractor from the dealer or did you put regular gear oil? I have seen numerous youtube videos of owners refilling the front axle with 75-90w synthetic or 80-90w regular gear oil. I am a new owner of a CK3520 Kioti tractor and I am a little confused why the tractor originally came with hydraulic fluid. Maybe just for break in? I am still waiting to get the tractor from the dealer so I don't even have the owners manual yet. Thanks for any reply.
   / cx2510 front axle oil change #5
They did it for ease of assemly. I'm not sure how much I'm gonna worry about it right now, for mine. Maybe not at all. Some people like to run High Viscosity lubricants but I'm not one of them.
If it ain't broke, fix it 'til it is :unsure:
I was told that yes, it was for the break in period, and I put in 80W-90.
As it turns out, I should have watched that video again before I started, because a bait bucket would have caught all the fluid.
I still have to change the hydro filter. I don't need a technician to show me how to change a filter, I just need to lift the machine a little. I just wondered how others would go about doing so.
   / cx2510 front axle oil change #8
Hi all!
Often there is not enough room for a big set of channel locks, I have a chain wrench which always works well for me, once it's on it requires minimal room for rotation and has good grip.
With the backhoe attachment on raising the tractor is easy, use the hoe to raise the tractor and the out riggers to stabilize it, then lift the front with the loader bucket, once up you can use stands or blocks as desired.
   / cx2510 front axle oil change #9
X2 on the chain wrench, particularly on the notoriously difficult first filter.
Other considerations are catching the oil during filter change, and forgetting to check for doubled up gaskets. On my last 2 tractors changing the transmission filter results in minimal fluid loss, and the hydraulic filter will dump gallons of fluid. My OEM schedule calls for the transmission filter at 200h and the hydraulic filter at 400h (same time for the UTF anyway).
It just seems weird to me to use car things. I keep expecting to need different tools or something. Stupid newbie questions ha ha.
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
11' CONTAINER (A52706)
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2004 Jeep Liberty Limited SUV (A55853)
2004 Jeep Liberty...
2005 Sterling Acterra Tender Truck (A57024)
2005 Sterling...
