CX2510 Cab - Can You Identify These Electrical Plugs?
   / CX2510 Cab - Can You Identify These Electrical Plugs? #1
WB2ORJ
Kioti CX2510 HST Cab
I need to bring out a 12vdc line to the rear of my tractor for a tow behind sprayer whose motor is rated at 8amps. Wire size of 18 or 20 AWG should be enough and I found two unused, capped electrical harnesses in the rear of the tractor. The first picture shows one at the top of the cab and the second is behind the rear toolbox. Both seem to be at least 20AWG and I assume they are there for some external implement use. I have asked the dealer a few times with no success and the only available service shop manual doesn't show wiring for the Cab model. I can pull fuses to see what circuit they may be part of but was hoping someone on the Forum has gone through this before. Ideally would be best to have a on-off switch among the rocker switches cutouts along the right side armrest. Any advice appreciated.
   / CX2510 Cab - Can You Identify These Electrical Plugs? #2
Use the power then run a ground wire back to the switch and ground the switch. That will break the circuit.
   / CX2510 Cab - Can You Identify These Electrical Plugs? #3
The first picture looks like the right rear of the cab. I found this picture of the beacon kit that attaches on that bracket and uses that plug.
Can't tell where that other plug is located by your picture
Wow, thats great. Where did you get the picture of the Cab with the beacon? Would be great to find a service/shop manual for the Cab even a CK model.
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
2015 Parker Trailer (A57148)
2015 Parker...
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A56858)
2007 Mitsubishi...
250 Traffic Cones (A57454)
250 Traffic Cones...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2005 Suzuki King Quad 700 Fourwheeler (A57453)
2005 Suzuki King...
