CVT vs HST
/ CVT vs HST #21
there is alot of information in this thread thats not correct...I don't have time to set things straight right now.
Please explain.
I do know that they use CVT on some combines. My neighbor bought a used Gleaner combine last fall and he let me crawl around inside it. I was surprised to see a giant pulley and CVT belt on a piece of equipment this large. He gave me a ride in this combine while he was harvesting last fall. It's a nice combine and he is very pleased with it. This is the first post about tractor CVT's I have seen on TBN. I would very much like to read more.
Are you sure that was driving the wheels?
/ CVT vs HST #22
I have a friend thats an engineer for a heavy equipment manufacturer. I asked him about CVT. He speaks very highly of the concept. He described several different types. The best designs aren't available on CUTs because they would be cost prohibitive.
He also said the real benefit of CVT is fuel economy, especially when an engine is designed to run at a constant, specified RPM. He thinks that in time CVT will become much more common.
/ CVT vs HST #23
Combines are hydrostatic, not CVT.
df.
/ CVT vs HST #24
Please explain.
To tell you the truth I can't say for sure. I asked the owner if the CVT pulley set up was the transmission drive and he said yes. Perhaps neither one of us knew what we are talking about. I am out of my league on this subject and have more to learn than to share.
/ CVT vs HST #26
Boomer 8N is very interesting. I looked thru the specs. Everything good til I saw it didnt have independent brakes. No thanks.
larry
/ CVT vs HST #27
larry
Larry, I remember there was a poster here on TBN that mentioned a split brake "kit" was available for the 8N. I don't know that it is true or not, but it might be worth asking a knowledgeable dealer if that is the deal breaker for you...
/ CVT vs HST #28
YES! Ill check that out.
larry
/ CVT vs HST #29
larry
Go to New Holland Ag website. Click on "parts & service", select "search for parts", type in "boomer 8n" in the search box, click search, click on "boomer 8n tractor", click on "transmission", scroll down and you'll find a listing for the dual brake pedal kit.
/ CVT vs HST #30
Absolutely agree with you on that. I'm no expert on them but from what I understand they are very efficient. Speed is controlled by variably rotating the ring gear of a planetary set with a hydraulic motor. Power input is on the sun pinion and power out is from the carrier of the planet gears. Full power is available directly through the planetarys. They appear to be pretty simple to me. Not sure where the high pressures would be needed. Certainly not for the hydraulic motor as it is only for speed regulation, not power. Don't remember if there are hydraulic clutches involved, but if so they would not need more than a couple hundred PSI. Hopefully someone with more knowledge can shed more light on this subject.
Kim
/ CVT vs HST #31
Kim
You have the closest explanation yet for a tractor CVT. Lots of misinformation in the prior posts. Unfortunately, CVT has been used for various types of transmissions. The tractor CVT tranny is not quite like that of a car, combine or atv.
Exploring the rise in sales of tractors equipped with CVT | News | Farmers Guardian
Here is an article that is way over my head.http://asae.frymulti.com/data/pdf/6/cvtt2005/lectureseries29rev.pdf
/ CVT vs HST #32
Combines DO NOT USE IVT/CVT. They are still HST - HUGE DIFFERENCE!!
df.
/ CVT vs HST #36
Kim
Let's set the record straight....
A number of people have CLAIMED that CVTs offer better efficiency, I said they did not and explained why. Because people won't look for themselves and LEARN the various CVT designs and how they operate in the vehicle (car, bus, tractor) does not mean assumptions about pressure are valid.
I did some research, Deere does offer a few IVT/CVT models in the US but there are many more offerings overseas for all mfgrs. I also said, and said again that CVTs are GREAT for the control of ground speed but are NOT more efficient because what looks good on paper does not prove out in the field. There are engineering limitations and to get traction of the friction elements you need PRESSURE or you will get SLIP and that makes heat, LOTS of it. The drive pressure of a CVT/IVT can be hydraulic of mechanical, but it is still there. Doubt it all you want, that's fine. Let me know how your clutch works w/o a pressure plate.
According to the Nebraska Tractor Test....
Deere 7430 w/IVT (http://tractortestlab.unl.edu/Deere/JohnDeere_7430 IVT.pdf)
Max PTO HP = 161.22
Max Drawbar HP = 126.57 (78.51% of PTO)
Deere 7420 w/GST (http://tractortestlab.unl.edu/Deere/JD_7420.pdf)
Max PTO HP = 127.38
Max Drawbar = 102.86 (80.75% of PTO)
So, do tell, which transmission got more HP to the ground as a percentage of the PTO power? Yea, the gear.
BTW, I quoted the original sources above, feel free to notice those numbers are not my opinion but tested facts.
/ CVT vs HST #38
Max PTO HP = 161.22
Max PTO HP = 127.38
I have read articles that a CVT is less efficient than a pure gear driven tractors and there are studies that show that is true. However, these studies are at heavy tillage (or in the NE studies at max performance) and conditons that demand high hp and even then difference is relatively small. The reason many claim the CVT is more efficient is because in many situations, max continious hp is not required. The CVT can better match tractor speed to the power requirements. Therefore, less fuel maybe required and greater productivity for tasks that may have changing power requirements.
/ CVT vs HST #39
df.
Again read the earlier article I listed. It depends on the definition of CVT. The drive belt of some combines is a type of CVT. The drive belt is on a mechanical pulley system that is variable in how the belt rotates on the pulley. It is more similar to the CVT of an atv. It is not the type of CVT/IVT more typically associated with a tractor.
/ CVT vs HST #40
I think this is a correct statement. CVT can be the variable speed pulley/belt set up. I have seen this on a Gleaner combine.
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2022 EZ-GO ELITE...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
