CVT software update
   / CVT software update #1
farmall40
Bronze Member
2010 Farmall 40 cvt
My dealer was out to the house yesterday to do a update on the cvt. He said he did not know what it was suposed to but he would find out and let me know. He also fixed the hard steering under load problem, and the gurgling/fluid noise coming from the steering. Had to remove the entire column for this fix. As soon as I can work the tractor again I'll let ya know if I see any Diff in the CVT.
   / CVT software update #2
I've got my fingers crossed. Do you happen to know what version the update was?
   / CVT software update #3
It was probably an ADIC update to version 1.2 I'm not sure what the changes affect other than the ground speed display.
   / CVT software update #4
I certainly would like to hear about this also.
Well I had a chance to use the tractor yesterday and was very displeased with the update. Everything is the same except for 3rd gear. has absolutely no power in 3rd, the most rpm I could get going down the road was 2000. It used to be great in 3rd, would go to whatever rpm I wanted. I called the dealer this morning and told them what the problem is. They told me they would be out on wednesday to put the factory program back in. I souldn't have let them do in the first place.
   / CVT software update #6
That sucks, I wonder if New Holland is even working on the problems. I noticed on mine there is a lot of play in the throttle cable coming off the pedal. If you take that slack out it will raise the RPMs higher and won't bog down so quick. The only disadvantage is you loose some ability to creep.
   / CVT software update #7
I have drove the Boomer 8N before the update and after the update in the computer. Definatly a big improvement in operation and shifting with the new update. Tractor operates best when oil is warm.
Dealer came back out today and reprogrammed again with a different version,6.3 I think. All the power is back and then some. I am very happy with this update.
Charging Cart (A51695)
Bluebird F-20B Lawn Comber (A51695)
Bluebird F-20B...
CAT CS563 (A47477)
CAT CS563 (A47477)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
