CV joint replacement Gator 620i
   / CV joint replacement Gator 620i #1
cad58y
College Station, TX
Ford1700. New Holland 3010
I need to replace the outer CV boot on on my 620i Gator. I have the axle shaft out but cannot get the inner CV joint separated from the axle shaft. The technical manual shows it held in place by a snap ring, however on my axle there is a retaining ring which I cannot remove. Suggestions appreciated. Bob Smits
   / CV joint replacement Gator 620i #2
Remove the Outer CV joint to replace the Outer Boot...
How do you remove the outer CV Joint?? I have searched U Tube and Googled it with no help.
   / CV joint replacement Gator 620i #4
Some cv joints have a retaining ring around the outer edge of the cv joint just inside the leading edge where the balls run. Others have a retaining ring around the shaft itself, In which you have to secure the axle in a patted vise, and then carefully drive the splined part of the cv joint off the shaft with a brass punch, if you don't have access to the special tool.
Thanks for the replies. I will give it a try.
Thanks RandyT. I followed your directions and it separated easily. Nowhere is this detailed in the Technical Manual.
   / CV joint replacement Gator 620i #7
And if you need to replace them again in the future, ACV is always worth checking out for aftermarket parts
2019 JOHN DEERE 210G LC EXCAVATOR (A45046)
2019 JOHN DEERE...
2013 CAT D6K2 XL Dozer (A42203)
2013 CAT D6K2 XL...
132917 (A44391)
132917 (A44391)
AGT QK20R Mini Excavator (A44501)
AGT QK20R Mini...
YANMAR VIO17 MINI EXCAVATOR (A45333)
YANMAR VIO17 MINI...
295 - 5951 18in CAT Bucket (A44391)
295 - 5951 18in...
