Price Check cv joint maintanence
   / cv joint maintanence #1
1965tontruck
Is there any maintanence that needs to be done on the 4 cv joints? I checked the owners manual for grease points and did not see anything. In addition, any maintanence for the rear suspension?
Thanks for the help.
   / cv joint maintanence #2
None that I know.
Thanks for the input radman. I search high and low for grease fittings.
   / cv joint maintanence #4
If you've got a "D" model, and it sounds like you do, there is a traditional zerk on the top of each upper ball joint (I guess that's what they're called) for a total of four suspension-related zerks. One zerk for each corner of the machine. I'm not aware of anything CV joint specific. If you don't see the zerk on top of the ball joint, it may mean that it was torn-off due to debris, loose tire chains, etc. The front and rear differentials also take a special lube that is supposed to be changed-out after the first 1000 hours.
A Bobcat technician once warned me about over-lubing the ball joints. He gave each zerk one or two pumps of grease.
I have an A model, but you givesome food advice.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
CAT MINI EXCAVATOR 303C (A50854)
CAT MINI EXCAVATOR...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
