Cutting Torch Question
   / Cutting Torch Question #1
rgood
SW Iowa
John Deere 3020
Hi,
I know that some cutting torches run on Acetylene and some run on Propane.
I also know at a certain pressure Acetylene can be very dangerous - It can cause an explosion.
If I use propane in a cutting torch, at what pressure range is it usually used and at what pressure is it dangerous?
   / Cutting Torch Question #2
Acetylene should never be run at any pressure over 15 PSI MAX. AND never use Copper fittings or Copper pipe with Acetylene gas. Only brass with less that 40% copper is allowed.
I've never seen a propane cutting torch.
Larry
   / Cutting Torch Question #4
I have used propane on the railroad and it requires a different setup on your torch head and tip. I personally didn't think that it got as hot but it's much cheaper if all you do is cut. Though I never tried it, I was told that you can't braze with it. I still use Acetylene at home because from time to time I'll braze something. I sure don't like buying it! (Acetylene) $$$
BD
   / Cutting Torch Question #5
propane is all I use to cut with. need a new tip specifically for propane. and I think I run my propane at about 7 psi and oxygen at 21 I want to say oxygen needs to be 3 times propane pressure. cuts good for my uses and I always have propane at home. But it is amazing how long a tank lasts the O2 will run out long before the fuel
   / Cutting Torch Question #6
Acy runs about 5 PSI in use (flowing)
If you want to see an Oxy Propane if you have a local scrap yard, that is probably what they are using. For lots and lots of straight forward (but usually rather crude) cutting, it is the most efficient.
   / Cutting Torch Question #7
Just wondering. Talking propane torching. Is it the same as MAP gas. That is a very good torch fuel (don't know about brazing) and cheap compared to acetyline.
Harry K
   / Cutting Torch Question #8
Have you considered a plasma machine? the prices have came way down.
the cut is much cleaner ( means less cleanup on the cut material )
The initial cost is more but the savings on the consumables, gas, oxy, grinding disks is much less in the long run
   / Cutting Torch Question #9
MAPP gas is Methylacetylene-Propadine. It can be used for heating, brazing, metalizing, soldering, flame hardening and cutting. Mapp gas produces a flame temperature of 5301° F (2927° )
Propane produces a lower flame temperature than acetylene (the maximum flame temperature in oxygen is 2,828°C compared with 3,160°C for acetylene).
Propane is heavier than air so we don't use it much in ship building aroung here.
Thanks for the replies - Is there a pressure at which propane is dangerous?
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
IH 445 Square Baler (A50515)
IH 445 Square...
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
2014 UTILITY DRY VAN TRAILER (A51222)
2014 UTILITY DRY...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
