cutting threaded end
/ cutting threaded end #1
firemanpat2910
Platinum Member
Havana Fla
Ford 2910II
I may have to cut 1/2 inch off the threaded end of a cyl.
is there anything special I need to worry about? or just whack it off? I think my air cut off tool will cut it but was wondering about a sawzall with a tungsten carbide blade.
This is not on a tractor its on a big paper cutter.
/ cutting threaded end #2
I have cut several down and used a 4 1/2" angle grinder w/cutting disk. I did extend the rod out as far as I could just to make sure there was no heat transfer to any of the seals. No problems whatsoever.
I have never used a tungston blade in my sawzall so I dont know how it would do but I can tell you, the rods I have cut were very hard. I don't think a regular metal cutting blade would touch them.
/ cutting threaded end #3
Most rods have a surface hardening of less than 1/10". The cutting of the threads will remove any hardening. The rod acts as such a heat sink that you will not overheat the seals. Your saw-zall should cut it okay. You will sweat a little, :) but it will cut. My choices for cutting this would be, in order of choice, portable band saw, then 4 1/2" grinder with cutting wheel, saw-zall, hack saw, dull butterknife.
/ cutting threaded end #4
FIREMAN:
I have cut several of these as I have modified several donor tie rod
cylinders. Since the rods seem to be chromed, or at least had hard
surfaces, there was no way I was going to risk damaging the bi-metal
blade in my horizontal bandsaw. The bandsaw does give the best cut.
I have used my plasma cutter, but that does not leave the best finish
as the rods I cut are over an inch thick. The last three I cut with my
cheapo HF 14" abrasive cutoff saw. Since this saw is for light duty use,
I just cut gradually from all sides until I got through. Works fine and
no blades were sacrificed.
thanks for the reply's. I dont yet know if I will have to cut the rod or not, but when the time comes I will let you know the results.
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2011 Ford Expedition SUV (A64557)
2011 Ford...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2004 MACK CV (GRANITE) KILL TRUCK (A65643)
2004 MACK CV...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2011 PETERBILT 367 (A65643)
2011 PETERBILT 367...
