Cutting the last row of grass
   / Cutting the last row of grass #11
Leave it! Next time you mow you will have a starting point and maybe a goal to do better this time mowing! :cool2:
on the seroius side, I use the center of the deck . . . . John
   / Cutting the last row of grass #12
Better planning next time so that the last row is precisely the correct width :)
Keith
   / Cutting the last row of grass #13
You should go out with white chalk like they use on football stadiums, mark off exactly the width of the mower with 10% overlap on the whole lawn, then you will have all the lanes marked and no left over narrow or little too wide for last pass.
On serious side, mowing is not rocket science and no need to over engineer or over think it, just pass the blades over the uncut grass and it will be OK till next week. Kinda like a bad haircut, in a couple of weeks, no one will notice if you have an error.
   / Cutting the last row of grass #14
What is the best technique to cut the last row ( when it is narrower than the normal row) with a right side discharge mower deck.? :cool2:
(1) favor the left side of the deck
(2) center up on it
(3) favor the right side of the deck
Define "favor". The discharge side of the mower should be aligned with the right edge of the last row. This will create a path of consistence width (assuming that's your goal?) if you mow counter-clockwise.
   / Cutting the last row of grass #15
Do it in a figure 8 so you cover all your bases.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2007 Volvo VNL Truck Tractor (A56435)
2007 Volvo VNL...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2022 Chevrolet Express (A57148)
2022 Chevrolet...
JOHN DEERE 9 SHANK CHISEL PLOW (A52708)
JOHN DEERE 9 SHANK...
2014 Ford F-250 Crew Cab 4X4 Pickup Truck (A55973)
2014 Ford F-250...
