Cutting Steel with a Circular Saw
   / Cutting Steel with a Circular Saw #1
ClintBlake
Mechanicsville, VA, USA
Power-Trac PT-422
I needed to cut 6 steel plates that are 5/16" thick and 6" wide. Never missing an opportunity to buy a new tool, I purchased the Evolution Rage Multi-purpose Saw for $149 online at Evolution Rage. This is a 7 1/4" circular saw designed to cut just about everything so I figured I would give it a try. The saw made the cuts in the steel with just about the same effort and time as a regular circular saw would cut standard 2x6 lumber. When the cut was finished, the steel was still cool to the touch and required very little dressing.
How does this relate to the Power-trac forum? Well, how many threads are there about making custom attachments? The saw can even make bevel cuts that are ready to weld.
   / Cutting Steel with a Circular Saw #2
Clint showed me the cut this morning and it looked very nice. This saw cuts many times faster than my band saw and the cut is just about as good.
This was mention on HGTV's website during the national hardware show.
   / Cutting Steel with a Circular Saw #3
I note that the blade is sold separately for $25. I wonder if this blade could be used on a stardard heavy duty hand saw that uses a 7 1/4" blade?
   / Cutting Steel with a Circular Saw #5
I use a Morse Metal Devil blade in my circular saw for cutting steel and it does a decent job.
   / Cutting Steel with a Circular Saw #6
I believe that there may be issues with metal particles getting into the motor of a normal circular saw. Clint Blake, do you agree.
The short answer is yes you can use the blade on a standard circular saw. The main problems I see is that the evolution saw is designed to catch most of the metal debri in a special guard and it also has a shield to allow you to watch the blade where it contacts the metal without getting pelted with metal chips. I would still very strongly encourage use of safety goggles or safety glasses and face shield.
I almost bought the bigger evolution saw with the Morse blade. The Morse blade is more expensive than the evolution blade, but it can be purchased locally.
   / Cutting Steel with a Circular Saw #9
Great! I buy a 40 amp plasma cutter and then read about a saw that nearly replaces it at a small fractiion of the cost. Oh well, the saw can't do silhouette art in sheet metal.++++++++++++++++ Pat
   / Cutting Steel with a Circular Saw #10
Island Tractor and patrick g, beat me to it.
But for the price I think I would end up with the saw also.
steve
2015 MACK PINNACLE (A53843)
2015 MACK PINNACLE...
JOHN DEERE CP690 LOT NUMBER 245 (A53084)
JOHN DEERE CP690...
UNUSED LANDHERO LDHGAC40V AIR COMPRESSOR (A51248)
UNUSED LANDHERO...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
John Deere 772-A Grader (A52384)
John Deere 772-A...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
