Cutting Round Bales - Chainsaw?
   / Cutting Round Bales - Chainsaw? #21
I have an old electric chainsaw gathering dust, and my plan is to modify the blade
A chainsaw does not have a "blade". It has a chain. That chain has teeth.
..., replace the oil with vegetable oil,
Bad idea. Vegetable oil will polymerize when exposed to oxygen. That means it will harden. Think tung oil on your chain. And in the oil passages. I once killed a chainsaw that way. :thumbdown:
Mineral oil won't do that, and won't poison your cattle.
   / Cutting Round Bales - Chainsaw? #22
Has anyone unrolled a bale, seen it done around these part's?
Ronnie
But my suggestions work way more easily than trying to cut pieces of a bale off while it is lying on its side...
I don't have the option of transporting the bale to the livestock, I don't have the space to lay a round bale on its side and unwind it, and if I make this too difficult for my wife (whose physical capabilities you are unaware of), I will end up doing this myself every day all winter. So the plan is, for this one year we will use round bales, is for me to hack the bale up into usable chunks that she can easily handle, estimate the weight of, and feed her horses. It's not efficient, but that's the way it has to be this year. Next year I'll harvest my small squares and all will be right with the world.
   / Cutting Round Bales - Chainsaw? #25
Hey guys, when my Dad was still farming we used an electric chainsaw. We used the top Of the bar to cut the bale. This kept the hay from clogging up the saw as quick
   / Cutting Round Bales - Chainsaw? #26
Well..um.. I might have to try that someday. The straw bale planting idea sounds interesting. Good luck with the greenhouse. It sounds like a ventilation issue?
Using the top of the bar is what that fellow did in the video in this thread.
   / Cutting Round Bales - Chainsaw? #28
Ronnie
On one of the Dr. Pole episodes a dairy farmer has an overhead lift on a track. They showed him with the bale hung on a spike through the center, unrolling it in front of the cows along a feeder. Looked like a simple set up. The spike looked like and oversized ice block tongs with the lifting eye.When you pick up it wood spear the center.
   / Cutting Round Bales - Chainsaw? #29
I have one of those, it's just a decoration at the barn & something for folks to ask questions about. I told them i'd hang the kids up when they were younger & misbehaving with it:D
Ronnie
1980 PULLMAN DRYVAN (A58214)
1980 PULLMAN...
(6) BOXES OF NAPKIN HOLDERS (A58374)
(6) BOXES OF...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58216)
HYDRAULIC AUGER...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
2006 Hackney T/A Hazmat Truck (A56858)
2006 Hackney T/A...
ELECTRIC PIZZA WARMER (A58374)
ELECTRIC PIZZA...
