"cutting edge" steel - Fab questions
   / "cutting edge" steel - Fab questions #11
Reddirt,
There are 2 cutting edge types available. The one you require is weldable edge. It's the stuff that is on FEL buckets. The bolt on edges are high carbon steel and they don't weld easy. Can be done, but you have to use your Ox/Ac torch and pre-heat the snit out of the edge, weld, heat, weld, heat, weld then post heat and slow cool. The old hands have it down pat, I don't! You can tell you didn't heat it correctly when it cools you hear "rice crispies" sounds and by the time it is cold, a big ugly hunk of the edge may physically pop out. Even real pretty pro quality looking beads. You really don't want those issues attaching the edge to the bucket nor the tooth shanks to the edge.
When you get the weldable edge, you can get them pre-punched for bolt on edge. That's the ticket. Then you can have 2 bolt on edges. One that is flat and smooth and one with teeth. Probably only 3-4 bolts needed.
Good luck with the project.
jb
   / "cutting edge" steel - Fab questions #12
RedDirt, i was telling about the leaf springs because the purpose i personally had in mind, which came to mind when you mentioned buckets and hardened steel...
I have a cutting edge on my FEL bucket but i need some digging teeth.
Some leaf springs are straight, though most of them these days are parabolic because they give a smoother ride.
   / "cutting edge" steel - Fab questions #14
jwmorris said:
I made some "teeth" for an auger a few years ago, I used cold rolled steel, after machining I hardened the parts using Kasenit hardening compound. They have held up better than the originals.
MidwayUSA - Kasenit Surface Hardening Compound 1 lb
That looks like some good stuff, so I ordered (back-ordered,:( not in stock) some. I can see many uses around my shop for it. I hope it don't stay back-ordered too long.
   / "cutting edge" steel - Fab questions #15
that kasenit is good, easily toughten any material, heat with a torch bright red, dip in let soak, re heat and presto good to go, quench if you want harder, its good because it only hardens the outside even hot rolled steel, one other way is highways or city engineering, the graders or snow trucks have wear edges bolted on, when they wear they are usually garbage, keep in mind they typically have 2 edges and only one gets used, great for cutting edges on buckets,
   / "cutting edge" steel - Fab questions #16
Hi Ray,
Thought I'd throw in my 2 cents...at least my Humble Opinions.
1. Do I need bone fide "cutting edge" steel stock or can I just use Hot Rolled flat steel and grind the bevel edge myself (taking care not to overheat the metal)?
You state in your opening post your ground is not too rocky and mostly clay an fairly "soft", so I think you could use hot roll or cold rolled steel.
2. If using a torch to cut a) cutting edge steel or b) hot rolled flat steel, does the heat at the cut destroy the "toughness" of the steel? Is this just at the cut line or does the heat "travel" some distance from the cut and affect the temper of the plate overall?
Hot roll and cold roll are not that tough to begin with. I think cutting with a torch or welding on them would probably harden those areas harder than the parent material is. I wouldn't worry about the heat migrating too much. It should be alright after welding.
3. What is the best method to cut a) cutting edge steel or b) hot rolled flat steel to preserve their tough qualities? I have a bandsaw, hand hacksaw, Sawzall, abrasive chop saw, torch, and thin grinder blades at my disposal. I don't know anyone with plasma equipment. I'm thinking a tough (Lenox) bi-metal blade in the Sawzall may be best and least damaging. Like cutting stainless plate, firm, steady feed pressure may keep the Sawzall blade from dulling and case hardening.
Well, the best method IMHO would be to saw it with coolant, next would be whatever you find to work best with what you got. Again, if you're going to use hrs or crs you don't need to worry about cutting pre-hardened steel like a true cutting edge. If you do get some, I'd still try to saw it first then perhaps use a cut-off wheel on your abrasive saw. I wouldn't worry about any loss of hardness since I think regular hrs or crs would work anyway.
4. If using high carbon hot rolled steel and beveling the edge myself should I temper the piece before welding it on the bucket? Before or after the beveling is done?
I don't think you need to worry about that for your usage.
5. Does pre-heating before or "slow cooling" after welding help preserve the toughness of these two metals?
That is always the preferred method to use any time you can. I would recommend you do that if possible. However, there are times it's not practical to do so. If you strip weld small areas at a time and allow ample cooling in between you should be alright.
Like I said, those are my opinions and others may disagree.
BTW, what part of the Sierra's are you in? I'm in them also.
3RRL said:
Hi Ray,
Rob,
Thanks for your 2 cents, they're appreciated. Collectively there's a wealth of good info on TBN; great community.
I'm East of Oroville, about 1 1/2 hrs north of Sacramento. Upper foothills, lower mountains, 3000ft elevation. Where are you?
   / "cutting edge" steel - Fab questions #18
I'm in the foothills below Sequoia National Park in a small town called Three Rivers. I'm only at 1600' elevation but you would think it was up higher than that from the countryside.
Well, when you get your bucket project going, I'm sure all of us would love to see pictures of it. While you're at it, post some pictures of your country side too. I'll bet it's beautiful up there.
   / "cutting edge" steel - Fab questions #20
you should be able to get away with most any steel on that size machine. i am a heavy equipment operator and when i work in the oil refineries no teeth are allowed. so flat stock is welded to the teeth for digging this lessens the chance of snagging or puncturing utility lines it will slide over it. the flat steel last a long time on these big machines corners wear the fastest but they are rounded from the start so there are no sharp edges. it does make it harder to dig something you might want to consider.
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
WATER TRAILER (A58214)
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
