Cutting edge for NH 14LA loader bucket.
   / Cutting edge for NH 14LA loader bucket. #1
ranger13256
northville, ny
New Holland
I am looking for a cutting edge for my NH 14LA QR loader bucket on my 2005 NH TC29 DA. It is 68" wide and has 8 holes. Any ideas?
   / Cutting edge for NH 14LA loader bucket. #2
I bought mine from the dealer when I bought my tractor. Don't know if they are still available but it seems like a common part that could be used across many different tractors.
Thanks, you would think that it is a common part, but I have been googleing and so far nothing. I have not tried the local NH dealer yet, everything is so expensive there.
   / Cutting edge for NH 14LA loader bucket. #4
The bolt patterns between my Land Pride rear blade and HLA front blade are exactly the same (both 7' edges). Perhaps your bucket edge has a standard set of holes?
There are plenty of companies that sell snow plow and bucket edges that let you specify the bolt pattern.
Great, can you please name a few coompanies that do that. Thanks
   / Cutting edge for NH 14LA loader bucket. #6
It would make sense that cutting edges would be a standard bolt pattern but they are not.
The 14LA 68" bucket uses a 716427016 cutting edge, held on by 280969 #3 plow bolts 1/2"x 1-3/4" long. The cutting edge seems to run about $450.
You might be able to get the cutting edge made by a place that makes heavy equipment cutting edges, but they are generally still pretty expensive. I am not aware of anyone offering a cutting edge for the 14LA buckets on the aftermarket.
CATERPILLAR CS563 SMOOTH DRUM ROLLER (A51246)
CATERPILLAR CS563...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A53472)
2022 JCB 3TS-8T...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2005 JLG E300AJP TELESCOPIC MANLIFT (A51246)
2005 JLG E300AJP...
