Cutting down a 60" rear blade to 54"
   / Cutting down a 60" rear blade to 54" #1
ericher69
Ontario Canada
2008 Kubota b2920
Considering cutting down my 60" rear blade (mostly used for snow) down to 54"
Reason; front blower is 51" and I get lots of spoil now
Will still need some blower "wings" but will only need 2-3 inches per side compared to 5-6 inches per side now
Tractor is kubota b2920 (1500lbs dry weight) not counting blower, undercarriage, rear blade and sims cab
I have zero issue with pto horses lacking!
Let me know what u think
Thx
   / Cutting down a 60" rear blade to 54" #2
Not sure what you are trying to accomplish by cutting it down. for snow you would want a rear blade a little bigger than if you were just using it for dirt.
A smaller blade will cut better, but require more passes.
I cut a 7.5' snow plow down to 6.5' because I feel it's the right fit for my machine. big enough, but not so big that I can't push it.
I also cut a 5 foot bucket to 4 foot just for a sidewalk that could get buried by street snow plow.
So I'm all for cutting down if it will suit your needs.
JB.
   / Cutting down a 60" rear blade to 54" #3
Do you ever angle the rear blade? if you angle a 60 in blade it will be less than 54 inches pretty quick
Jb
My blower is currently 9" narrower than rear blade...
Spoil ++ when doing first pass and edge passes
Thought about wings but 5.5-6 inches per side is a bit much
I thought about angling but I need straight to remove snow close to buildings etc.
Unless I go hydraulic angling?
   / Cutting down a 60" rear blade to 54" #5
Jb
Can't you just get off the tractor and manually angle the blade perpendicular (straight) to the tractor...or even a bit (15 degrees or so) away from the buildings? It really isn't that mch work, is it?
Personally, I think you'd regret cutting that blade down...
Royjackson;
I'm not lazy but...
Getting in and out of a cab at least twice per drive at 50+ residential drives per snow fall adds up to major time wasted and $$
   / Cutting down a 60" rear blade to 54" #7
If you are doing this for money, then you need to keep the full width blade and make it so that it has hydraulic angling. :thumbsup:
   / Cutting down a 60" rear blade to 54" #9
Royjackson;
I'm not lazy but...
Yes, it would...I thought you were doing this for your home only.
You'd be better off with a front blade (for most snows...6-8 inches of less), I think.
   / Cutting down a 60" rear blade to 54" #10
If you have a blower, why the need for a blade at all.??
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2016 John Deere 6145M (A50120)
2016 John Deere...
10X12 PUMP (A52472)
10X12 PUMP (A52472)
