Cutting ditch with FEL?
   / Cutting ditch with FEL? #11
Yes, with a box blade you would scrape and create a small pile then pick it up with the loader. That may sound like a slow process but I'll bet it would be a lot faster than trying to do it with just the FEL.
A backhoe is NOT what you want. Generally they only dig directly off the rear and you can only dump it 90 degrees to the side....another pile you have to pick up and move. I guess a really big one might be able to do some decent digging to the side if the ground is soft enough. I have a small BH (Kubota B-21) that I've used to clear the ditch on the side our of driveway. Real mess since the mud ends up on the driveway and then I have to try to move that. For the type of operation you want (dig it on one side and dump it on the other side of the road, you need a mini excavator with a long enough reach. They can dig on one side and dump 180 degrees away.
Ken
Thanks for all the comments. Gives me some ideas of what I am in for.
No rocks, no roots, not heavy clay... I can get crossways in spots but it is only 10 - 12 feet wide for some of it. It's a good job for a backhoe as I would like to put the material on the other side of the road but I don't have one. I do have a box blade but what would be the steps? I guess it would be use the box blade to dig the ditch with dirt ending up on the road (and some on the other side of the ditch). Then come back with the FEL to clean up and move the dirt? If I can cut it with the FEL I figured it would be less time as I can just dump the dirt where I want it as I go but now that I think about it I may be wrong. I may try cutting pretty much level the first pass and see how it goes.
I couldn't really do the fully bucket width - I guess I could but don't want a ditch the full bucket width. I could move the tractor over and cut the ditch with the other side of the bucket but I would be at steeper side slope so that doesn't seem good.
   / Cutting ditch with FEL? #12
A couple other things. It will go a lot easier with a toothbar. If the soil is wet and packeted down, as you dig into it, pulling down of the front of the tractor, be prepared that this dirt could just pop out and the front of the tractor will jump up a little or at lease feel like it did.
Let us know how it worked out for you and any lessons learned.
   / Cutting ditch with FEL? #13
Soil type will have an impact. I have on occassion had to bury a dead calf and even a cow. When I do this I count on the FEL hydraulics alot ... degree of angle, curl the bucket ... you can damage things using 4WD and getting rough.
   / Cutting ditch with FEL? #14
I have a bachhoe, but I cleaned out my ditch using the FEL 2 years ago. I learned that when my rear tires is on a slop, my cutting angle is on a slope as well, so smaller cuts after the first one is needed to make it all flow together. I would have started on the bank but its quite steep at 45 degrees and it was tough to control the forward movement as the gravity was pulling me in faster then I wanted to even with HST.
   / Cutting ditch with FEL? #15
   / Cutting ditch with FEL? #16
Check out the post "Drainage Ditch". By Egon.
It shows some pictures of a trench dug aB7100 and FEL.:)
   / Cutting ditch with FEL? #17
Let Ted from Everythingattachments demonstrate. Go to about 5:00 min into it.
[ame=http://www.youtube.com/watch?v=LxuEDGSGOZA&feature=player_embedded]How to Use a Box Blade - YouTube[/ame]
HP
   / Cutting ditch with FEL? #18
Thaks for the pictures
   / Cutting ditch with FEL? #19
Great thread! Thanks for the video as well. This is my project for tomorrow morning. I have a drainage that has accumulated erosion over the years and I want to clean it back up to where water will flow as it should. Was wondering how to get the angle right and thought I'd have to cut from sides with FEL until shape was there then use box blade. Now I know how to adjust the box blade angle so this should be much easier. What the steepest side slope you'd drive on? 20 degrees? One side is uphill, the other is flat. The uphill side has eroded into the drainage because of insufficient ground cover when originally cut in.
   / Cutting ditch with FEL? #20
After a season or so you wont have a ditch as wide as you made it, due to erosion.
I would use the box and just drive the length wise of the ditch, that would give the best job IMO.
A box blade used like that parallel to the work is very forgiving, going at it at a right angle is gonna to be very messy.
JB
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
Giyi Breaker Hammer (A57149)
Giyi Breaker...
2016 Ford Expedition SUV (A56859)
2016 Ford...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
20FT X 30FT STEEL CARPORT (A58216)
20FT X 30FT STEEL...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
