Cutting ditch with FEL?
   / Cutting ditch with FEL? #1
JimS
Bronze Member
Want to cut a shallow ditch along a road and thinking I could do it with my FEL. (Kubota 3600) Ground slopes up from the road on one side . Road itself is practically level. I am thinking if I cut out at the start (should be easy as it is more level there) and run the tractor with one wheel on the road and one in the (shallow) ditch I should be able to cut a modest ditch. Need to do about 150 feet. I will be getting someone with a trackhoe to cut out more eventually but need to get something done now for cheap. Road isn't wide enough to use tractor cross ways of road. In the slightly less steep places I might be able to come at it down the hill but suspect I might be more likely to get stuck if I get hung up and can't get traction to back up the hill.
Just wondering what people think of the idea and any suggestions.
   / Cutting ditch with FEL? #2
I've cut ditches with my bucket before I had my backhoe. Take your time and I think you'll get it done.
   / Cutting ditch with FEL? #3
Well to be honest with you, I don't think it will work at all. Trying to just cut thru dirt with the side of your loader , and the tractor over on an angle is just going to "hog in" the loader ,in other words it will not cut, and just try to turn over the tractor. Now I have cut several trench's like the above poster by using the FEL and using your curl/breakout and the pressure of the tractor moving forward all at the same time.. Now this works well and if you don't have too many rocks. is quite fast. The Hydrostat is your friend here as it makes the tractor pressure part easy. Now I have done it plenty of times with a gear tractor too, it is just hard on the clutch/throwout bearing. You must have an extremely narrow road, as I can place my tractor accross my very narrow road and clean out the ditch. Now of course this is just my opinion, and you are welcome by me to try:) But I think you will have no success. Hopefully others will chime in here with their experience/opinion.
James K0UA
   / Cutting ditch with FEL? #4
If you have access to a box blade, you can angle that up a good bit on your 3ph to cut the ditch.
   / Cutting ditch with FEL? #6
Go slow and give it try.
May become hard digging if big rock or roots show up...do you have back blade if not borrow one,than off set blade go slow dig the ditch depth for now.
   / Cutting ditch with FEL? #7
I have similar project so I would be interested in the out come. I have a ditch that just has debris in it (corn stalks and such) Not a deep ditch so mt thought was to run with the ditch and let the end of the bucket clean out the bottom. I plan to do my project Monday so I will post my out come and hopefuly I don't report that I turned my tractor over:)
   / Cutting ditch with FEL? #8
I dug a short ditch (about 20 feet long) with the FEL a week ago. Due to space constraints and what I thought was safer, I cut into it perpendicular to the ditch direction. So I had to make 5-6 cuts moving down the line to create the ditch. It was a matter of setting the bucket position and angle, driving forward, and then curling back the bucket at the right time. I made it about 8-10" deep and 2' wide.
I wouldn't want to do this for a real long ditch, but for short runs it works fine, and you completely avoid getting the tractor sideways in the ditch. You're always approaching from the side.
   / Cutting ditch with FEL? #9
It depends very much on the soil type and the traction you have. Heavy clay? It's not going to work very well. Rock? Forget it.
Do NOT try overpowering it by ramming. Since you are only digging on one side, the off balance pressure could twist the FEL. Don't forget, you do not have an "excavator", but rather a "front end LOADER".
Also, if you do get it to work, as you progress, the ditch will get more shallow.
It will work MUCH better if you have a tooth bar.
I agree that a box blade or scraper blade is probably the best way to go.
If it is a county or township road, have you talked to them about doing it? Around here they periodically ditch the road sides.
Ken
Thanks for all the comments. Gives me some ideas of what I am in for.
No rocks, no roots, not heavy clay... I can get crossways in spots but it is only 10 - 12 feet wide for some of it. It's a good job for a backhoe as I would like to put the material on the other side of the road but I don't have one. I do have a box blade but what would be the steps? I guess it would be use the box blade to dig the ditch with dirt ending up on the road (and some on the other side of the ditch). Then come back with the FEL to clean up and move the dirt? If I can cut it with the FEL I figured it would be less time as I can just dump the dirt where I want it as I go but now that I think about it I may be wrong. I may try cutting pretty much level the first pass and see how it goes.
I couldn't really do the fully bucket width - I guess I could but don't want a ditch the full bucket width. I could move the tractor over and cut the ditch with the other side of the bucket but I would be at steeper side slope so that doesn't seem good.
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
Pull-Behind Smooth Drum Ballast Roller (A52377)
Pull-Behind Smooth...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
