Cutting an access road on a slope
   / Cutting an access road on a slope #21
Here's a picture showing use of the rock debris to build a dry stack rock/soil wall to help keep the next area of filled dirt in place.
I was fairly lucky that the cut area on the hillside produced a lot of rocks that were fairly flat which made stacking easier. I was also lucky to have a number of long rocks that could be stacked from the wall back into the fill so that soil compression of the fill helps to keep the drystack wall in place.
Now I just need to move the shed out of the way to complete the transition to the existing driveway. :thumbsup:
   / Cutting an access road on a slope #22
The road is nearly completed.
Shed at the end of the driveway removed and remaining work beginning.
Road nearly completed.
Now, I just need a good rain to help consolidate the soil and so that I can further modify the angle back towards the hillside and drainage pipes. Probably won't happen until October or November given its Southern California, although we do get the occasional summer monsoonal storm that over flows from the Gulf of Baja.
   / Cutting an access road on a slope #23
Looking good!
Moisture and compaction makes makes a world of difference in my trailblazing too.
New Holland LB75B (A51573)
New Holland LB75B...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2008 JOHN DEERE 6330 LOT NUMBER 98 (A53084)
2008 JOHN DEERE...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
