cutting a little steel
   / cutting a little steel #1
Professor Marvel
Platinum Member
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
Looking for suggestions for a fairly inexpensive way to cut steel up to maybe 1/4 in. I will only need to cut steel occasionally but I want to be able to make the shapes I need to make repairs on farm equipment (mower decks, wagons etc). I don't need anything commercial but I don't like junk either.
   / cutting a little steel #2
What's your budget? An oxy/acetylene torch would be cheapest. A full blown CAD operated, computerized cutter would be the other end of the equation.
   / cutting a little steel #3
This is a fairly inexpensive way to cut steel. :thumbsup:
SA
Sorry, I explained it inaccurately. A hack saw is indeed fine for cutting stock but I was wondering about sheet type metal. An example is repairing a deck on a bushog.
I am certainly considering a torch. I guess I was just hoping somebody might know of a saw or possibly other device that I had not though about or be aware of.
   / cutting a little steel #6
SA
These work good for that, a lot more money tho. :eek:
   / cutting a little steel #7
Budget.
For a tractor owner, a Oxy Fuel torch is the most versatile tool. From cutting metal to being able to heat and bend or loosen rusted fasteners.
For purely cutting, the sawzall or the milwaulkee metal circ saw would work.
A plain old 4.5" grinder with a zip cut would work too, and a grinder is an essential piece of equipment
   / cutting a little steel #8
How about a nibbler. The small air powered ones can go up to 16ga.
Bigger ones get expensive real quick.
Or a body saw. Works like a mini sawzall.
   / cutting a little steel #9
If you go with a torch, use propane to save some money. Takes a little longer on the preheat, but does make some nice cuts.
   / cutting a little steel #10
I've heard of using propane, but never done it. What pressure do you set the regulator at for something like 1/4" mild steel? Same pressure on Oxygen as the acetylene set up? Same tip?
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
2005 Butler Pole Trailer, 25000 GVWR (A52384)
2005 Butler Pole...
2019 Nissan Versa Sedan (A51694)
2019 Nissan Versa...
