Mowing cutter for BX2200
/ cutter for BX2200 #1
mark120950
waterloo, il
kubota BX2200
I'm a newbie with 15 acres of trees and prairies to maintain in the Waterloo, Il area... I'm in need of a pto operated brush cutter, and other pto accesories like log spliiters etc but i'm not sure what would be appropriate for this small tractor...and so i'm looking for new or used equipment but i don't see much in this area ....any suggestions are welcome
thanks
Mark
/ cutter for BX2200 #2
Used equipment is hard to find in the size appropriate for the BX2200. Woods makes a good rotary cutter as does Land Pride and probably Bush Hog. Check your manual to see what size is recommended and you can usually go up a little from that. I am unaware of any PTO powered log splitter, but check the Woods site for their equipment line to get ideas. Good luck, the BX2200 is a good little tractor.
/ cutter for BX2200 #3
If all you are cutting is wild tall grass, a number of 48" light and medium duty rotary cutters would be fine. 60" would really be pushing it for a BX. If you need to cut denser material, a 40" Heavy Duty Gearmore model is what will work well. I have one on my BX2200 and am able to cut clusters of 2" saplings with it.
For a rear log splitter, you will probably need to tap into the port that's available for a rear remote hydro line. I had that line put on mine when I got the Woods BH6000 backhoe. Now that the hydro line is in place, other rear hydraulics such as log splitter, top 'n tilt, etc. could be used.
2003 Sterling L9500 Series T/A Wet Kit Day Cab Truck Tractor (A59230)
2003 Sterling...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A59228)
2018 Toro Z-Master...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
