Cutter Bar VS Tooth Bar
   / Cutter Bar VS Tooth Bar #1
catfishsteved
Texas - Ellis County
TC40D
I figure a $180.00 bar is cheaper than a dented/knicked up FEL bucket. Mine is the HD one but i load my dumptruck fairly often with rock and some are pretty large --bucket size. What's the difference in the two used for? Also, does any one know the cost and part # for the front grill guard to fit a TC 40D.
   / Cutter Bar VS Tooth Bar #2
Hi Steve........I own both the tooth bar and cutter bar. I use the tooth bar for digging. The cutter bar is used where I want to leave it smooth or leave a clean surface (as on a concrete pad, etc). For rock I would use my tooth bar. I also own the grille guard. I don't know the part # but I recall paying 80 to 100 for it.
   / Cutter Bar VS Tooth Bar #3
Steve, the grill guard part number is 719849006. Mine was priced at $229, but you might get a better deal. An important consideration about getting the NH guard is that it is compatible with NH suitcase weights also. If you have a loader, you probably don't need the weights, but if you remove the loader, you may need them. I've attached a photo of my tractor with the grill guard installed. If you look closely, you will see the cutter bar mounted on my loader bucket. It was $179 and is really worth the money. I'll also be getting a toothbar soon. NH's toothbar won't fit over the cutter bar, but there is a third-party brand which will. I like the cutter bar for the extra strength and the toothbar for digging.
   / Cutter Bar VS Tooth Bar #4
Jim,
Who makes the toothbar that fits over our cutting bar? I'd like one myself.
Danny
   / Cutter Bar VS Tooth Bar #5
For about $300 for a 72" bucket or about $250 for a 60" bucket, you should contact KC Canary @ 1-800-920-7097. Ask for Mark Bruckner and give him the details. I have not bought from him yet, but everyone I talk to says he will give you the best deal and he sells a toothbar which will fit over the cutter bar. You may need to make some measurements related to the hole pattern and such, but he can surely tell you more.
UNUSED FUTURE 32"...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
Electric Utility Cart (A56857)
Electric Utility...
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
