CUT vs Skid Steer
/ CUT vs Skid Steer #81
Xfaxman, I'm going to have to ask you to refrain from posting more pictures of your telehandler. It's giving me an extreme case of envy. :D
That isn't the V417 compact telehandler, it is my wife's Toolcat. :D
For those newbies that haven't seen it, here it is with the 7' brush hog. Don't drool on your keyboard.:)
/ CUT vs Skid Steer #82
That isn't the V417 compact telehandler, it is my wife's Toolcat. :D For those newbies that haven't seen it, here it is with the 7' brush hog. Don't drool on your keyboard.:) <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=475982"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=475983"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=475984"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=475985"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=475986"/>
I see it has a 3point hitch on the back. Does it have a PTO too? Disregard I just looked at another photo of it and saw it.
/ CUT vs Skid Steer #83
The biggest problem with a cut is not being able to see the bucket edge vs clear visibility on a skid steer. Fine grading is tough, but 3pt attachments can help with that. Just to be clear that I'm only comparing a skid steer to a hydrostatic cut as a gear drive or shuttle shift is not as comparable in my opinion. If dirt is what you deal with the most then get a skid steer. Bottom line it's all budget and usage. I'd have both if I could afford it, but I still want and would use a skid steer even though I have a cut..
/ CUT vs Skid Steer #84
The loader on a tractor is a bass awkwards impliment. In a real machine, you have the heavy engine in back for ballast & the weak complex expensive steering axle away from the heavy lifting. Exactly the opposite of how a tractor is setup.
My dad said the old Allis Chalmers were easy to reverse. He said he was involved in several conversions.
Here's one on youtube. Reversed WC Allis loader tractor - YouTube
/ CUT vs Skid Steer #85
Seen a few old tractors setup like that, only with a forklift mast on or instead of a 3pt. Definitely the right way to design a machine from an engineering point of view, rather than putting the loader on the front. Ballast/engine in the rear, weak axle in the rear, beefy axle under the load, etc. Generally skid steeres are setup that way too, at least they get the ballast right & eliminate the weak axle entirely.
If you need to dig & move dirt or only lift stuff, get a skid steere, as that is what they are designed for If you need to mow, plow, or the most flexible option for a pile of different stuff, get a tractor.
/ CUT vs Skid Steer #86
I was thinking about this and first there was a tractor, then there came the skid steer. If the skid steer can do everything a tractor can do why are they still making and selling so many tractors? Did most of the major brands, many of whom make skid steers, not realize the skid steer was invented?
Yes, I adapted this from the "If we came from apes, why are there still apes?" debate. :)
/ CUT vs Skid Steer #87
Skid steers get stuck easier and are usually way heavier. They also have limited movement compared to a backhoe and they don't have 3pt hitches.
However they are fantastic for loading dirt and gravel, have good hydraulic power/flow and run a lot of front mounted implements very well and have a great view and are easy to climb in and out of.
They arent made for plowing but are more purpose built. Tractors do more but usually less heavy duty when it comes to quick attach implements.
/ CUT vs Skid Steer #88
Tractors are the Swiss army knife of powered machinery. The SS is a specialty machine.
/ CUT vs Skid Steer #89
We had pocket knives, then they invented scalpels. So why do people still mostly use pocket knives... Because the original tool is more versatile & useful in more situations.
/ CUT vs Skid Steer #90
Are you a midget? I climbed in an out of a John Deere 250 mid range skid steer and it was a big pain. If I had size 7 shoes and was 5' tall maybe it would be easy. :D
/ CUT vs Skid Steer #91
You step on the bucket and basically fall backwards in the seat. You must be old.
/ CUT vs Skid Steer #93
I guess it depends on the tractor as well. My cab tractor is a pain to get into compared to a skid steer. But my old 8n is pretty easy to jump on.
/ CUT vs Skid Steer #94
My V417 cab is easy to step into:
Unless when compressing a brush pile and I jump out to take a picture:
/ CUT vs Skid Steer #95
Does it compress brush better with the wheels 3 feet off the ground vs 3 inches?
/ CUT vs Skid Steer #96
No, but you can't see that both wheels are off the ground at 3 inches. :thumbsup:
/ CUT vs Skid Steer #97
O.K., that post with pics just confirms I did a lousy job of life planning! :laughing:
/ CUT vs Skid Steer #98
I have been helping a friend clear land with a Gehl 9800 pound skid steer. No surprise it beats the heck out of a tractor for loader work, but a tractor is much better suited for the average landowner. My tractor does the task I do and the majority of the work I have seen done in the seat time thread better than a skid steer.
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
72" Grapple Attachment (A60462)
72" Grapple...
SD Lanch 20'x30' All Steel Carport (A60462)
SD Lanch 20'x30'...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
Freighliner Tender Truck (A61307)
Freighliner Tender...
