CUT vs Skid Steer
/ CUT vs Skid Steer
Seems to be turning into a "which is better" thread. Let's remember the ops uses, light FEL work.
Yeah, it is, but that's OK. This thread is less about me and more about what you guys are doing. That's what I really wanted to know. I think we're getting that just fine. It's a good conversation.
/ CUT vs Skid Steer #43
Sweet! Well in that case, my answer is completely different, definitely get the Skidsteer, WAY more capable.
/ CUT vs Skid Steer #44
whatever machine you get should be appropriate for the work you need to do with it. You description of your needs point to a tractor.
/ CUT vs Skid Steer
I agree, oldpilgrim, and a CUT is the direction I'm headed. But since the subject came up, I thought I'd toss it around here to see what others are doing.
Since my wife works in the heavy construction industry (as a project analyst, not a constructor), we have access to all manner of earth-moving equipment should we need it. For our own personal everyday use, though, a tractor just seems to make the most sense.
/ CUT vs Skid Steer #46
I don't know if you are into this or not, but it is easier socializing with the neighbors when you are putzing around on a CUT. Just road gear it over to his house in the neighborhood and have a little bro-time. Much nicer than running a tank over.
/ CUT vs Skid Steer #47
True Dat. I've had many good conversations either from my tractor seat, or with someone on a tractor. Occasionally even both. Never have really chatted with anyone in a skid steer.
/ CUT vs Skid Steer #48
Oh, you know pretty much every person here would drop their bromance with the tractor guy next door for the tank guy down the street in a heartbeat! :laughing:
/ CUT vs Skid Steer #49
The loader on a tractor is a bass awkwards impliment. In a real machine, you have the heavy engine in back for ballast & the weak complex expensive steering axle away from the heavy lifting. Exactly the opposite of how a tractor is setup. Which kills lift capacity as you don't have the ballast & the steering axle is the weak link. It's only up there for the flexibility & visibility. Would make a lot more sense to mount em with the bucket over the 3pt (there are a few bidirectional tractors out there like this). But a tractor is primarily a pulling machine, not a digging machine. So the loader is an afterthought.
On a SS, the loader is the only use able impliment, so the whole machine is properly designed to maximize it's abilities & effectiveness.
Personally I own a tractor with an afterthought loader & am looking at replacing it with another cabbed tractor with afterthought loader. I like the flexibility of the machine, the roading & ride comfort. I don't do enough digging to justify a SS.
/ CUT vs Skid Steer #50
I guess that means my put together is a real machine :D
The front axle does not pivot, the rear steering axle does.
/ CUT vs Skid Steer
Fascinating. Am I to assume you built this, Xfaxman? Is there a thread here somewhere that shows/explains this beast?
(edit: Duh ... bozo here just found the link in your signature line)
/ CUT vs Skid Steer #53
Yep and the thread is in my signature.
/ CUT vs Skid Steer #55
A tractor is kind of a "Jack of all trades", whereas a SS is a specific purpose machine.
There is a huge price difference too.
Other than digging and running high-volume hydraulic SS attachments, everything else on a SS is a jury-rig trying to do what a tractor does well (3ph attachments on the front, etc.)
I use a grading scraper to groom my drive. Don't see a SS doing that. At least not very well.
I can dig. I can run hydraulic SS attachments on my tractor. Just not as fast as SS.
/ CUT vs Skid Steer #56
I guess you haven't seen the Grading scrapers made for skid steers:
And the laser controlled precision type:
/ CUT vs Skid Steer #57
Yup. Your little home brew machine is noticeably less machine than my factory L3200 & loader, but has almost the same lift capacity.
Better designed for the task of lifting. Mine will plow & grade circles around yours though. I'd say mine would mow circles around yours too, but I have a suspicion that wasn't the case in a previous life.
/ CUT vs Skid Steer #58
Yup. Your little home brew machine is noticeably less machine than my factory L3200 & loader, but has almost the same lift capacity. Better designed for the task of lifting. Mine will plow & grade circles around yours though. I'd say mine would mow circles around yours too, but I have a suspicion that wasn't the case in a previous life.
In its previous life it had a 72" deck. In a mowing contest you'll be begging for mercy and go home with your tail between your legs.
/ CUT vs Skid Steer #59
In its previous live it had a 72" deck. In a mowing contest you'll be begging for mercy and go home with your tail between your legs.
Yep, this 72" side discharge deck is just one of the many front mount attachments made for the 300 series Groundsmaster.
/ CUT vs Skid Steer #60
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Portable Chicken Coop (A66408)
Portable Chicken...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2019 East...
