cut out
/ cut out #1
slammer3364
Jinma 284
I have a craftsman 21 horse 46 in cut hydro-stat mower. It runs great until you engage mower then it cuts out backfires and almost shuts off any advice greatly appreciated Thanks Slammer
/ cut out #2
Is it a newer model? Mine will do that if the mower goes into reverse unless you have the key turned to the mow in reverse position. Maybe the reverse sensor is stuck and the mower thinks you're trying to go in reverse and killing the engine.
/ cut out
took the sensor apart on wire harness and it did the same thing. I found the unit that the blade is connected to is coming apart on the pressed bushing,I am thinking this is my problem,any ideas Thanks
/ cut out #4
Are you talking about the mandrel assembly? If so, I would doubt if that is the reason that it is cutting out when you engage the blade, unless you have a seized up mandrel or idler pulley bearing but you would definitely smell the belt burning if that was the case. Is yours a twin cylinder?
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
White 5409 9ft. Disc Mower (A65640)
White 5409 9ft...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
39' 9" 3 Bar Drag Tooth Harrow (A66285)
39' 9" 3 Bar Drag...
