CUT Hour meter broken - what to do?
   / CUT Hour meter broken - what to do? #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
My 2002 4310 has about 700 hours, but the hour mete is all black and distorted display - unreadable.
The official fix is a replacement cluster. $700 and may require programming.
Of course, I am hoping to sell it and not mislead anyone.
A meter set to 0000 won't look good. A used one with way more hours would hurt the value.
Ideas?
   / CUT Hour meter broken - what to do? #2
On the 790 my instrument cluster would fog not to long after I bought it. The dealer replaced the cluster under warranty and placed one of those Dymo lables in the lower right hand on the window of the cluster that says 'add 250 hours'.
   / CUT Hour meter broken - what to do? #3
Personally I'd tear into it and see how difficult it would be to replace just the LCD screen. Im not sure what makes them go all black but could also be a loose connection.
If you're not into electronics and $700 is too much then you're probably stuck looking for a used dash. Does it count up with just the key on or does it require tach input? I should know because my 4400 is also LCD, but honestly never paid attention. If it's just battery voltage, might try hooking it up to a battery for a couple months until it rolls over. Wait another 29 or so days and you'll be back at 700.
Here's a video of someone replacing a different Deere dash LCD.
repair of John Deere dashboard - YouTube
   / CUT Hour meter broken - what to do? #4
You could get an ordinary hour meter and install it somewhere convenient. And from your maintenance notes add the hours if and when you sell it.....just to stay honest. Those meters are commonly available for a few bucks...IIRC. Or, maybe the $700 JD could be recouped a bit when you sell it.....assuming the rest of the machine looks all that good.
Wow! Thx I will look that way. BTW, it gets a pulse from the alternator. like .04V I think
   / CUT Hour meter broken - what to do? #6
Maybe someone else can comment on the 0.04V.
I double checked the Tech Manual - "Pulsed current flows from the “P” terminal of the alternator to the instrument panel (X8 connector, terminal F) through the 325 Dk Grn wire." Normal is .04 volts.
I am curious if anyone has opened a Deere CUT instrument cluster. Is it a sealed unit, or can it be easily opened?
   / CUT Hour meter broken - what to do? #9
If you just want to keep track of the hours for maintenance purposes, visit a dirt bike shop and get one that just attaches to the motor without wiring. I assume they have a battery inside that activates the meter when the motor is running.
thx. The problem is that i want to sell the tractor. If I can repair the cluster, it may make a big difference
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
