Customized instument cluster - In search of inspiration
   / Customized instument cluster - In search of inspiration #1
CanadianBeaverS370
St-Telesphore,Qc
Satoh Beaver and IH B414 FEL
Hi Every one,
Thinking a building a custom instrument cluster ( as my tractor has a lack of Tach, oil, fuel and temp gauges ) just warning light ... yes very boring :confused:
looking for ideas. Can you guys post me some pix of your custom mods and add-ons.
Dash space is minimal on my tractor. I am thinking of a nice custom hood mounted cluster.
What have you guys done ? I've seen some pretty creative things on here... just nothing like what I have in mind
   / Customized instument cluster - In search of inspiration #2
Although I have not built mine yet , I will be replacing the dash / cluster on my New Holland TC 30 . My reasoning is simple , COST !!! First gauge to go was the Fuel gauge , replacement cost at that time was $ 85 . On closer inspection of the broken gauge , I seen no reason to waste money on another one , so I bought a aftermarket gauge and float unit for $35 , ( including shipping ) , and have had no problems since , besides being more accurate !!
Since then the temp gauge has also gone ***'s Up , So I already have one of those but it is only installed in a temp. position , just to monitor while running . I'll end up keeping the tach and hour meter and basically just make a new face plate out of steel . Thought about Diamond Plate , but nixed that idea since I don't need the reflection off that blinding me . I figured just some sheet steel or 1/8" plate for face and go from there ??
Fred H.
   / Customized instument cluster - In search of inspiration #3
When I added some instrumentation to my B8200, I fabed, from aluminum sheet, this. I added a coolant temp. guage, voltmeter and oil pressure. The gauges cost under $20, including adapter fittings. Didn't require any dash space. (for some reason, you will have to click on the link to see the photo. It's worth it!)
   / Customized instument cluster - In search of inspiration #4
look at Princess Auto for the 3 gauges ( amps / temp and oil pressure ) when on sale ... or when the volts / etc ones come up ... they have bulbs in them to light up at night ... and a pretty good bezel to hold them ( or use the face plate and cut a hole to mount it )
going high tech and you can sometimes score the LED bar graph ones ...
   / Customized instument cluster - In search of inspiration #5
Canadian, changed mine out for newer style gauges. I kept the lights for oil pressure and temp, i think that by the time you notice the oil pressure at zero it's too late, at least the light will be flashing first, Just my take of it...
   / Customized instument cluster - In search of inspiration #6
That looks great.
   / Customized instument cluster - In search of inspiration #7
Glastron, you are right on about keeping the warning lights! I just tee'd and took my oil pressure from that, keeping the low pressure sender. Everything still worked, with the gauges just there for information. That cheap SunPro set also had backlights...
   / Customized instument cluster - In search of inspiration #8
Really nice work - if you hadn't said you made it I would have sworn it was a factory option.
You're making me rethink the whole "stock" thing, now.
2021 Deere 333G (A53317)
2021 Deere 333G...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2014 Ford F-150 Pickup Truck (A55852)
2014 Ford F-150...
2006 Ford F-750 Stellar 6620 6,000 LB 3 Ton Crane Mechanics Truck (A55852)
2006 Ford F-750...
