Customized brush guard kioti dk 4720 se
   / Customized brush guard kioti dk 4720 se #1
Nb707
2020 kioti 4710 se hst cab
It happened to me just like many have posted, a brand new tractor using my grapple thought I was extremely careful and the dreaded stick branch went right through my grill. :( anyways . The part was $95 about 2 hours of labor to remove and replace the part . Lesson learned. So I customize the solution Made this brush guard. I think it turned out pretty good
   / Customized brush guard kioti dk 4720 se #2
works now.....Looks good........:thumbsup:
   / Customized brush guard kioti dk 4720 se #3
I think so too :thumbsup:
gg
   / Customized brush guard kioti dk 4720 se #5
Great work, very clean look. I need this but don't have a welder. What was your method of construction?
More Photos
Welding and drilling all you need is about a 10 foot 1“ x 1/8 angle iron plus expandable metal from Home Depot the cost for both of them are about Just under $50. Plus I added 1“ x 1/8 trim around the back just to make it look nice and add more strength. But I must warn anybody who wants to do this. Drilling into the OEM grill guard was a ***** with a handheld drill. I had a very good Dewalt 18 V drill with brand new cobalt blades and it took me an hour to drill one hole you’re gonna need to drill about six holes. I said forget that and I end up buying at Home Depot a cheap drill press 169..oo bucks but what a difference that made, completely surprised how easy it was to drill with the drill press I use three different drill sizes starting with a pilot hole and it went through like butter. I have never built anything like this I’m not a machinist this took me a long time but I took my time lotta measuring and a lot of figuring out. But it turned out great.
   / Customized brush guard kioti dk 4720 se #10
Welding and drilling all you need is about a 10 foot 1“ x 1/8 angle iron plus expandable metal from Home Depot the cost for both of them are about Just under $50. But I must warn anybody who wants to do this. Drilling into the OEM grill guard was a ***** with a handheld drill. I had a very good Dewalt 18 V drill with brand new cobalt blades and it took me an hour to drill one hole you’re gonna need to drill about six holes. I said forget that and I end up buying at Home Depot a cheap drill press 169..oo bucks but what a difference that made, completely surprised how easy it was to drill with the drill press I use three different drill sizes starting with a pilot hole and it went through like butter. I have never built anything like this I’m not a machinist this took me a long time but I took my time lotta measuring and a lot of figuring out. But it turned out great.
I imagine you could sandwich the expanded metal to the angle iron with some flat bar and bolts. Notch the angle outer frame for corners and bend. Making it a weld-free screen would help some folks. Your grill protector and drill press experience will inspire many others
John Deere 5115M (A50120)
John Deere 5115M...
New Holland B95 Backhoe (A50490)
New Holland B95...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
