Customers Grapple build and convert Massey to SSQA
   / Customers Grapple build and convert Massey to SSQA #1
blueriver
Elite Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
Customer ordered an 84" grapple and change out his loader to SSQA ... Grapple teeth and lids are AR400 steel 3/8" ... dual lids with 2x8 cylinders.
off with the old
Box in for lever clearance
Test fit
Cut the parts
and finish up
   / Customers Grapple build and convert Massey to SSQA #2
WOW, that's one H**l of a Grapple for that size tractor!!!! Awesome!!!! :)
Thanks .... "the customer is always right" ... I suggested 72" but he wanted 84"
   / Customers Grapple build and convert Massey to SSQA #4
I think he well be back to make that smaller.
   / Customers Grapple build and convert Massey to SSQA #6
Everyone's uses are different. I'm in timber a lot, it would be too bulky for me. In open terrain I sometimes wish mine was wider.
You are right ... everyone's use is different ... I can suggest for open terrain just get another !!!!!
   / Customers Grapple build and convert Massey to SSQA #8
Kinda hard to tell from your picture, but the latch linkage doesn't look like it has any "over center" travel to keep the handles from bouncing up, unlatching one or both sides.
Where I added the arrow needs to be over farther (handle lower), so the compression spring will hold the handle down better.
Should be more like this, notice that the spring has to compress as the handle starts to raise.
You make a very good point and thank you ... I believe all is good it latches very secure.
Heres a 72" that went out week before last
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
LOT LOCATIONS (A53426)
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2012 INTERNATIONAL PROSTAR +122 EAGLE 6X4 ROAD TRA (A51247)
2012 INTERNATIONAL...
HURRICANE 5' X 10' CONTAINER (A51248)
HURRICANE 5' X 10'...
