"Customer Use" fuse on CK27...Where the heck is it?
   / "Customer Use" fuse on CK27...Where the heck is it? #11
I used the white two lead connector to wire a cigarette lighter plug for accessories. I also want to hook up 3 27w LED lights; one rearward and two forward facing. There are two bullet connectors on the right rear, one hot, one grund. I just don't know their amp rating. I also have a six-wire black weater tight plug down lower on the right side near the axle. I assume this is for trailer light connections as it has lights, turn signal and (I assume) brake light wires. Does anyone know what this connector is called or where I could pick one up?
I finally found my fuse box. It's on the top right side of the firewall. Inaccessible unless I remove the hood, air cleaner and FEL. WTF were they thinking?
   / "Customer Use" fuse on CK27...Where the heck is it? #12
Question on that customer spot in the fuse box. Is it a blank breaker spot that we can use ? I want to install a cigarette/ accessory plug and was wondering if I can get one of those breakers that has a wire built into it and plug it into the customer slot. Will that work?
   / "Customer Use" fuse on CK27...Where the heck is it? #13
Same question as above and still no answer. Does anyone know what that customer spot mean.
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
1998 INTERNATIONAL 4700 4X2 CRANE TRUCK (A57192)
1998 INTERNATIONAL...
AUCTION STARTS HERE @ 9AM (A52707)
AUCTION STARTS...
(2) BOXES OF (100) 3/8" X 27" SHAFTS (A57192)
(2) BOXES OF (100)...
2016 Ford Expedition SUV (A55853)
2016 Ford...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
